Sponsored by: Real Truck
Need some help with Keyless Entry
Old Oct 2, 2010 | 02:27 PM
Surge08's Avatar
Surge08
I have an 2004 F350 and looking to find where the KYE Module sits in this truck so I can check to see if I have the connections to support it. So I need pics or info from 1999 to 2004.
Old Oct 2, 2010 | 03:49 PM
dchamberlain's Avatar
dchamberlain
The VSM (Vehicle Security Module) controls the power door locks, door lock switches, the wired keypad (if you have it), remote keyless entry, wireless keypad and the auto lamps (if you have that).
It is tucked up on the firewall, behind the radio.
I don't know if there are different VSM's for trucks with different functions, or if there is just one generic VSM module and different functions are turned on or off in programming.
There don't appear to be any special connectors to the VSM for keyless entry. Just connections to the door lock/unlock switches, and the door lock actuators. There has to be a connection to the wired keypad, but my service manual doesn't show it.
Below is a diagram that sort of shows where the VSM is.
Old Oct 2, 2010 | 04:02 PM
Surge08's Avatar
Surge08
shows a blank image
Old Oct 2, 2010 | 04:12 PM
gearloose1's Avatar
gearloose1
Isn't keyless entry done via the back quarter window?
Old Oct 2, 2010 | 04:15 PM
Surge08's Avatar
Surge08
haha, Na trying to set it up in my truck.
Old Oct 2, 2010 | 06:28 PM
dchamberlain
I don't know why you can't see that picture. But try this...
http://www.chamberlain.homedns.org/misc/111967247.gif
Old Oct 2, 2010 | 07:33 PM
Surge08's Avatar
Surge08
What is connector C2113b and C2113c?
Old Oct 2, 2010 | 10:43 PM
dchamberlain
Connector C2113a, b and c are the connectors to the VSM.
http://www.chamberlain.homedns.org/misc/108687852.gif
http://www.chamberlain.homedns.org/misc/108687853.gif
Old Oct 2, 2010 | 11:01 PM
Surge08's Avatar
Surge08
One last question, where is the exact location of these connectors or vsm
Old Oct 2, 2010 | 11:06 PM
dchamberlain
It's basically up on the forward firewall behind the radio. You can see it by laying on the floor and looking up behind the dash behind the radio. The only real way to actually access will be to remove the radio and probably the black dash face.
Old Oct 2, 2010 | 11:16 PM
Surge08's Avatar
Surge08
ok will relook tomorrow, Had it apart earlier and couldn't find it
Old Oct 3, 2010 | 05:23 AM
merlins'92f250d's Avatar
merlins'92f250d
surge08...Are you trying to add the keyless entry?? I was wanting to do that to my 03 but the local dealer said that it was not possible...let me know how it works for you
Old Oct 3, 2010 | 09:37 AM
brd7666's Avatar
brd7666
If you are looking to add the keypad on the side of the door you can get one of these. This is what I have and they work on the same frequency as the fobs. No wiring at all, they just stick on the side of the truck with two sided tape. Mine works great and it was easy to install. It's also a genuine Ford part.
00-05 Ford Keyless entry Keypad OE Ford Accessory: eBay Motors (item 370438409270 end time Oct-03-10 10:37:23 PDT)
Ford Keyless entry Keypad : eBay Motors (item 370438409942 end time Oct-03-10 10:38:49 PDT)
If you have any questions, call the number listed in those auctions, ask for the parts department, and then ask for Dave.
Old Oct 3, 2010 | 01:03 PM
Surge08's Avatar
Surge08
Will do
Thanks for the info
David Masch
Feb 22, 2016 11:00 PM
lukesmith828
Jan 18, 2016 09:14 AM
jspec
2004 - 2008 F150
Nov 24, 2014 11:40 AM
fordiesel69
2004 - 2008 F150
Sep 27, 2014 06:55 AM
