Starting problems
Old Oct 2, 2010 | 12:05 PM
rustydailey's Avatar
rustydailey
Starting problems
The last couple of mornings I have tried to start my truck but it just doesn't start. It acts like it isn't getting fuel. I crank it for a min then turn the key off and try it again and after a couple of tries it finally starts. The first time I opened up the fuel filter to see if there was any fuel in it due to the angle I was parked, so I opened it up and looked at it and it was full of fuel. So I thought maybe the filter was clogged, so I changed it and it still happens. Does anyone have any advice on where to check next?
Old Oct 4, 2010 | 10:48 AM
Brother Les's Avatar
Brother Les
With the cooler weather, check your GPR and your batt voltage.
Old Oct 4, 2010 | 11:30 AM
oldgameandfishdiesel's Avatar
Having the same problem myself but was also wondering if it is normal for a truck to start a lot easier with a chip on it. just got rid of mine and it just doesnt start as easy as befor.
Old Oct 4, 2010 | 08:57 PM
jhelm2586's Avatar
jhelm2586
I had the same problem and 5 out of my 8 glow plugs were shot and my batterys were almost shot due to all the cranking I had to do to get it started and side note don't do a lot of cranking on it cause diesel starters are pricey
