Replaced Low Pressure Fuel Pump
Old Feb 22, 2003 | 12:04 PM
GSchretter's Avatar
GSchretter
Unhappy Replaced Low Pressure Fuel Pump
In front tank in a 87 f-150 302, but truck still dies.
If I switch to rear fuel tank everything works great ?
I can hear the front fuel pump running fine.
There is gas in the tank.
Any Idea ????
Do I need to replace the high pressure fuel pump ?
Thanks.
Old Feb 22, 2003 | 01:11 PM
GSchretter's Avatar
GSchretter
I just replace the high pressure fuel pump and there still is a problem.
I can hear the high pressure pump get really loud like it is getting not fuel.
Could it be that black round container that connect both tanks together ????
Old Feb 22, 2003 | 02:10 PM
Chas1234's Avatar
Chas1234
I think you just answered your own question try replacing that black canister..I think that will make it work
Old Feb 22, 2003 | 04:26 PM
GSchretter's Avatar
GSchretter
Cool Replaced Low Pressure Fuel Pump
It was the black round container.
Everything working great...
Old Feb 27, 2006 | 12:03 PM
iacpas's Avatar
iacpas
I was wondering, what is the black cannister called? I took mine off and need to get a new o-ring for it. I'm afraid that parts man won't know what I'm talking about.
Thanks,
Pat
Old Feb 27, 2006 | 05:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Pat to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 27, 2006 | 06:13 PM
subford's Avatar
subford
Thanks,
Pat
It is called a Dual Function Reservoir - 9B263 (base part number).
Here is a diagram of it.
Old Feb 27, 2006 | 06:14 PM
LoosMaster's Avatar
LoosMaster
Thanks,
Pat
It's called a Double Function Reservoir. Most Autoparts stores don't sell parts for it and the dealer sells only the unit. Expect to pay at least $90 US for it.
Old Feb 28, 2006 | 01:15 PM
iacpas's Avatar
iacpas
That part looks similar but mine looks like it might be deeper. I has a fuel pick-up tube sticking down into it plus there isn't a filter in it. I took it apart because my Haynes book said older model Rangers have that type of filter and the newer model have the traditional inline filter. (It didn't break it down as to whether '89 fell under "new" or "old". I didn't see the inline filter initially and ended up opening this thing up.
Thanks again for the help
Pat
