Sponsored by: Real Truck
Week long project almost done
Old Oct 2, 2010 | 10:43 AM
few2many's Avatar
few2many
So I got a near complete 6" lift off craiglist for real cheap. All I need is to fab the drop bracket for the track bar and fab the sway bar extensions. I started it sunday afternoon, mistake! Worked on it and hour or two each night after work, untill done(almost).
Old Oct 2, 2010 | 12:28 PM
bigblue61's Avatar
bigblue61
looks nice man...what size tires you running with that setup
Old Oct 2, 2010 | 08:13 PM
few2many's Avatar
few2many
They are 38's, but theyre kinda trashed. Gonna try 37's next and 35's if need be. The 38's dont feel bad at all. No noticeable loss of power or torque. 5.4 with 4.10's
Old Oct 2, 2010 | 10:13 PM
Fordfanatic4life's Avatar
Fordfanatic4life
for what its worth, you can safely ditch the sway bars on a lift kit of that height..
the spring pack will be stiff enuf that body roll wont really be a factor vs the stock soft springs.. your call.
but the trac bar fix is def required thou...
Old Oct 2, 2010 | 10:39 PM
99f350sd's Avatar
99f350sd
Got rid of the sway bar on my stock 99 with x springs and never noticed..even towing. Springs are way too stiff..as with a lift..
Dick
Old Oct 2, 2010 | 10:44 PM
few2many's Avatar
few2many
yeah, disconnected the sway bar the 2nd time I went offroad, the first time being the test drive. Had it disc for years, thought the sway bar would help due to extra height of truck.
But I am definitely feeling the lack of the track bar. Every bump jerks the wheel, especially cause the drop pitman is still on the work bench, couldnt wait to drive it down the street!
Old Oct 2, 2010 | 10:47 PM
99f350sd's Avatar
99f350sd
Very dangerous....Do the track rod correctly or you will have issues big time...need a drop pitman and a drop bracket so the two rods are parrallel.
Old Oct 2, 2010 | 11:03 PM
few2many's Avatar
few2many
Thanks for the concern, I know I need them, just getting there slowly.
Not really too dangerous, how long have there been front leaf sprung vehicles before common use of the track bar? 100 years? Its more of a comfort and high speed driveability thing. The track bar alleviates bump steer, especially on lifted trucks where it more noticeable. Also, hinders articulation when it comes to leafs. I have a '63 wagoneer and it has 9" of lift with just leaf springs and a z-shaped drag link. The bump steer is barely noticeable. But its also not to be loaded, tow with and hit 75 on the freeway.
Yeah, I'm pretty familliar with the geometry. What surprised me was the rear end. The lift blocks angle the pinion up, lessening the angle. But the lift increases the angle at the trans. My angles are definitely out from where they should be, but I'm seeing this is common for 90% of lifts out there. Yet, there are no vibes at all from the rear or driveline?
Old Oct 2, 2010 | 11:39 PM
Alex7191's Avatar
Alex7191
is it manual or auto? good looking truck the lift looks great
Old Oct 3, 2010 | 09:22 AM
few2many's Avatar
few2many
Thanks, its an auto.
transam525
258
Feb 23, 2026 06:45 PM
SideWinder4.9l
1966 - 1977 Early Broncos
30
Mar 22, 2012 02:28 PM
FatDan7.3
Projects
Jan 10, 2011 01:57 PM
FuelishPleasure
Nov 9, 2010 10:48 AM
offroadracer99
Oct 22, 2010 10:22 PM
