Bed bow
Old Sep 30, 2010 | 11:10 AM
skipr's Avatar
skipr
Bed bow
Looking for thoughts on how to straighten the front pannel of my box. It is bowed from cargo hitting it has no dents only bowed forward
Old Sep 30, 2010 | 11:19 AM
56panelford's Avatar
56panelford
Back it up against a pole and use a chain block to slowly pull it back into place. Make someting to cradle over the lip of the back panel to attach the hook, line it with rubber or cardboard to prevent scratching the paint if that's a concern. That's how I'd handle it any ways. Good luck and go slow.
Old Sep 30, 2010 | 04:33 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
This is especially a problem for those of us with the F-2/F-3 Express beds since reproduction headboards are not available. I'm not there yet myself, but have thought of using a similar technique as described by 56panelford. Besides the bends seen in the top rails, there are generally also bends and stretched areas in the interior area of the panel. I know that metal shrinking techniques exist, and will be schooling myself on these as well. I'd like to hear more of what others have done to remedy this problem. Stu
Old Sep 30, 2010 | 10:30 PM
Julies Cool F1's Avatar
Julies Cool F1
I just replaced mine. But, it's an F1 and the headboards are available in reproduction.
I am wondering how difficult it would be to pull the dish out of it some, then cover it on the inside with a full sheet metal panel cover that you weld in around the edges?
It would be flat sheet except for about a 1/2" 90 degree lip all the way around.
Old Oct 1, 2010 | 05:15 AM
truckdog62563
That'd be fine for a custom or other none stock remedy, but wouldn't be appropriate for a stock restoration. The metal shrinking technique that I'm most interested in learning about involves the heating of dime sized areas, quenching with water/air to pull the stretched metal back in, then hammer flattening and grinding of the high spots. I've wondered if that messes with the beads that are factory rolled into the headboards, and whether it can result in oil canning if done by a ham fisted amateur - like me. I think I've read that CDs on the technique are available from Ron Covall (sp?). Probably a search over on the body work forum would direct me to the source of the CDs. Stu
Old Oct 1, 2010 | 07:00 PM
carnut122's Avatar
carnut122
Cut it out and weld in a new panel?
Old Oct 1, 2010 | 07:05 PM
56panelford
I think that would be a bit extreem and expensive seeing as he said it is only bowed and not dented, I'd use my approach first. Just don't over do it.
rican69m
Florida Chapter
Oct 11, 2011 09:18 AM
DMAX-HD
Sep 30, 2004 09:12 AM
night_owl
23
Apr 20, 2004 08:16 AM
couleeman
Mar 29, 2004 01:25 PM
Scotty1
Oklahoma Chapter
Aug 9, 2002 12:15 PM
