Carb question, will it fit?
Old Sep 29, 2010 | 08:44 PM
dsmisfits's Avatar
dsmisfits
Its a recently rebuilt holley 650 cfm carb. Its a spread bore style carb 4 barrel. I have a 86 F250 with a 460. If this fits I am a happy guy.
Old Sep 29, 2010 | 11:26 PM
Redneck1465's Avatar
Redneck1465
Should fit without any problems as long as you have a 4v intake.
Old Sep 29, 2010 | 11:32 PM
dsmisfits's Avatar
dsmisfits
Thanks for your help.
Old Sep 30, 2010 | 04:45 AM
Old Hickory's Avatar
Old Hickory
If you have a stock Ford 4V intake you might have a problem if the 650 has larger
secondaries than the primary side. The stock Ford intake is made for a 4180 Motorcraft
Holley in which the primaries and secondaries are the same size. See if you can find a
carb to manifold gasket for your stock application and see how it fits to the manifold
side of the 650. This might save you some trouble.
Old Sep 30, 2010 | 09:55 AM
Franklin2's Avatar
Franklin2
Spreadbore is not going to fit a square bore manifold like was said in the previous post. They do make adapters though.
Old Sep 30, 2010 | 12:24 PM
dsmisfits's Avatar
dsmisfits
Thanks, for your help. I will take a look at it today.
Old Oct 1, 2010 | 05:57 PM
occupant's Avatar
occupant
The 4165/4175 spreadbore Holleys are 650cfm Quadrajet replacements IIRC. You can get a 3/4" thick or so adapter to fit on a square bore manifold, I've seen them as little as $13. Or you can find a GM guy somewhere who wants it and has a 4160/4180 you could use.
F250DUDE66
May 19, 2009 01:09 PM
IsoGrifo
Dec 8, 2007 06:20 PM
haulin4
Nov 9, 2004 04:13 PM
Chtulu473
Aug 21, 2003 09:53 AM
levilevi2
Nov 8, 2002 10:38 AM
