Air intake
Old Sep 29, 2010 | 05:13 AM
Powerstroke.07's Avatar
Powerstroke.07
Air intake
Hey Guys, I'm new to this website and new to a diesel engine. I'm removing a K&N air intake that the previous owner installed and going back to stock. Is there anything special that needs to be done? Is it as simple as removing the old and installing the new?
Thanks for the help
Old Sep 29, 2010 | 06:02 AM
npccpartsman's Avatar
npccpartsman
Not really anything special. Make sure you have all the pieces of the factory intake before you start. Should take you about 30 minutes or less to complete. The only thing you might want to do special is to get some MAF cleaner and spray off the MAF sensor when you switch it over (depending on how it's mounted to the K&N). Other than that....nothing special.
There was a video posted of a very very very easy way to change the factory air filter for maintenance. Maybe someone has it saved and will repost it. Makes changing the factory filter SUPER easy.
Old Sep 29, 2010 | 07:18 AM
Cowboy65's Avatar
Cowboy65
If you haven't already purchased your filter check out Diesel Filters Online. They have good prices on OEM air, fuel, & oil filters.
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Sep 29, 2010 | 07:19 AM
rsmarcil's Avatar
rsmarcil
https://www.powerstrokediesel.com/index.aspx?PageId=417
I'm downloading it as we speak. There's got to be an easier way. Hopefully this is it.
Old Sep 29, 2010 | 02:52 PM
npccpartsman
That's the video and that's about as easy as it gets for the factory filter IMHO.
