Brake Trouble
I have a 72 F250 with power assist brakes. Disc front and drum rear. The Master cylinder went bad. I replaced the master ( I didn't bench bleed the master as I didn't have a vise big enough to secure it ) The truck also has a trailer brake system and this has a line running from the resevoir for the rear brakes ( brass fitting w/ 2 outlets ) to the switch box in the cab.
I bolted the master on and hooked up all the lines and proceeded to bleed all four wheels hence, bleeding the master in the process. Or so I think? The only line I didn't bleed is the trailer brake line as I couldn't find anywhere to bleed it ( no bleeder screw? ).
The brakes work but the pedal does not come back all the way and when applied the pedal is almost to the floor.
One thing I noted when doing the bleeding was the rear resevoir would actually " geyser " fluid up when the brake was pumped. The front resevoir did not do this.
I went through bleeding all four wheels 3 times in this sequence: Right rear, left rear, right front, left front.
So my questions are ,
Should I disconnect the lines and try to bleed just the master and then go through all the lines again?
Should I just disconnect the trailer brake line and plug the port?
Should I try bleeding the trailer brake line by unscrewing the end that goes into the switch box? ( messy ).
I'm thinking the trailer line is the culprit but since I didn't bench bleed the master and it is doing that geyser thing maybe that is the problem.
Considering the pedal is so lame I'm wondering if that 3 foot line from the rear resevoir to the trailer brake box is really an issue? I know it really should be bled, it's just odd how there isn't a bleeder screw.
FWIW, The trailer brake switch box has a **** on it that moves left to right when the brake pedal is depressed and it does do it now.
To add to my explanation: I took out all the bleeder screws and wire wheeled them and cleaned out the drain holes. I also pulled out the lines from the master to the proportioning block? and snaked those.
I really need to get this truck back on the road since, ironically my brakes in my daily driver went out last week. I know that is not going to be a simple fix as I have already determined it isn't something I can easily diagnose ( if at all ).
The weather here was crappy yesterday and more scheduled for today so I probably won't be working on it until Wednesday.
Thanks for any help you guys can provide.
My worst case scenario is the master I bought is bad which is really going to drive me to drink since when I got it I degreased the outside and cleaned it ( I kept all the plugs in ) and shot it with chrome paint. Looks real purdy. They probably won't take it back now if I need another one.
