removing bolt from leaf spring bushing?
Old Sep 27, 2010 | 10:43 AM
jjoel's Avatar
jjoel
anyone ever tried to push the bolt out with like a gear puller?
http://www.northerntool.com/images/p.../153901_lg.jpg
I have this project coming up maybe this weekend and thought this may be a way to get that stubborn bolt out with relatively small mounts of pain.
Old Sep 27, 2010 | 03:41 PM
jplinville's Avatar
jplinville
The best way I've found is to completely remove the spring from the truck, and, while laying it on it's side against a brick or something equally hard, use a punch and a BFH to hammer it out.
Hope this helps some!
Old Sep 27, 2010 | 08:16 PM
deeznuts822's Avatar
deeznuts822
I used a ball joint press to get mine out,was much easier than cutting it.
Old Sep 28, 2010 | 11:31 AM
FarmallF-150's Avatar
FarmallF-150
i used a tie down strap and a pipe wrench lol not the safest thing in the world but redneck way gets the job done
Old Sep 28, 2010 | 01:43 PM
ExtrmZ's Avatar
ExtrmZ
i had to use a jack with some carefully places chains that held the spring down, while the jack only pushed up on the bolt. Yeah it was a lot of work
The BFH and a brick didnt work for me, it shattered the brick, and nothing happened.
If you could get your hands on a hydraulic press that would work too
Old Sep 28, 2010 | 02:50 PM
83project's Avatar
83project
burn it out
Old Sep 28, 2010 | 02:57 PM
732t37's Avatar
732t37
+1 on 83project's suggestion. If you're replacing worn suspension parts that bushing is probably pretty worn out too, and should be removed for replacement anyway.
Old Sep 29, 2010 | 05:55 PM
T C's Avatar
T C
I agree, heat the sleeve till it melts the rubber like a smore on a campfire and just slide it out.
Tedster9
Jan 18, 2015 12:50 AM
BigDoug
Jul 14, 2014 08:15 PM
sostock
Mar 4, 2014 09:17 PM
hotrodtodd
27
Oct 27, 2013 10:15 AM
moljeski
Nov 8, 2011 08:36 PM
