want shift from park
Old Sep 26, 2010 | 09:37 PM
montgomery7's Avatar
montgomery7
I have a 02 Ex. V10 4x4 the problem is it keeps blowing the number 34 fuse (brake lock switch) this also controlls the automatic climate controll, before i could make it about 3 weeks before it would blow a fuse but now it's blowing it when i put the fuse in. got to be a short. i also have no air up front fan or anything. any suggestions on this. i was thinking faulty brake lock switch what does anybody else think.
Old Sep 26, 2010 | 11:14 PM
wallz's Avatar
wallz
I bet if you check your cruise it also doesn't work! Had this same problem just over a yr ago. Ended up being the switch on the end of the master brake cylinder. There is a recall on that, they end up putting in a fused one. Mine also ended up being the cruise module. Do yourself a favour and get the switch checked out asap because it is known to cause fires. Then check to see if the cruise works, and if need be get used servo from the wreckers.
Old Sep 27, 2010 | 05:01 AM
dscwxwork's Avatar
dscwxwork
Yea, I agree. There is a switch in the break circuit somewhere. I have a 2000 and I dont remember seeing a recall. I bet its just a 6 buck part.
Temecula
d
