rear end swap
Old Sep 26, 2010 | 09:08 PM
contourdesigns's Avatar
contourdesigns
rear end swap
I don't know what rear end comes standard in a 1995 f350 dually with the 7.3 but I want to know if can be swapped with the rear end from a 1999 f350 dually because I think they have the same wheels and disc brakes.
Old Sep 26, 2010 | 09:37 PM
danger-ranger93's Avatar
danger-ranger93
it could be the stearling 10.25, or a D70. i'm sure a picture could help...
Old Sep 27, 2010 | 07:55 AM
rla2005's Avatar
rla2005
Both trucks should have a Sterling rear axle. I think the spring perch widths are different between the two as well as different wheel lug spacing.
Old Sep 27, 2010 | 08:50 AM
contourdesigns
Will the disc brakes on the 99 fit the axle on the 95? Has anybody tried that fix?
Old Sep 27, 2010 | 10:08 AM
jokerforever's Avatar
jokerforever
Okay, for the 95 they could of had a 10.25 or a Dana 70 or 80, I don't know which. The 99 will have a Dana 80. Either way, the 95 will have the old 8-lug pattern and the newer truck will have the new metric one.
Old Sep 27, 2010 | 01:46 PM
rla2005's Avatar
rla2005
I learn something new here everyday.... A previous post suggested getting a photo of the '99 year axle, that would be a good idea. According to this site: Randy's Ring & Pinion Ford Rear Differentials it could be a D70, D80 or Sterling 10.5". The Dana axles have a 10 bolt rear cover, the Sterling will have 12 bolts.
vettex2
Apr 13, 2014 06:19 PM
ptra2417
May 4, 2011 02:20 PM
brmkart14
Jun 11, 2004 11:14 PM
