Sponsored by: Real Truck
Intermittant issue
Old Sep 26, 2010 | 03:16 PM
jc8825's Avatar
jc8825
Intermittant issue
I know that it is a common problem, so I just need to know what to check. A while back I was having an electrical issue with fuse 35 blowing causing my radio and power windows to fail. The truck went to the dealer and they found the wire under the headliner, fixed it and no more blowing fuses or non-working stuff. Now, yesterday, I get into the truck after work and the radio and power windows weren't working. No blown fuses. I drove about 1/10th of a mile and the radio came on and the windows worked. This is the only time it has done this and I can't seem to get it to repeat, but I want to know what to check and fix. Thanks.
Old Sep 26, 2010 | 04:29 PM
gearloose1's Avatar
gearloose1
Simple.
Reset the computers. Follow link below.
Old Sep 26, 2010 | 04:37 PM
dchamberlain's Avatar
dchamberlain
The radio, power windows, map lights (I think) and power rear sliding window (if you have one) are all powered by the Accessory Delay Relay. This allows them to operate for awhile after the key is turned off.
The Accessory Delay Relay coil is powered by the HEC (instrument cluster) on newer trucks, or possibly the GEM on older trucks that have one. It is the "timer" that holds the relay closed while the key is on and for a period of time after it is turned off (or the doors are opened).
The cause of this problem is either the relay, or potentially a problem in the HEC or GEM. Most likely is the relay.
Old Sep 26, 2010 | 04:57 PM
gearloose1's Avatar
gearloose1
If a bad relay is suspected, go into the relay box up front, and substitute the relevant relay with another one in the box.
9 chance out of 10, a simple substitution of a frequently used relay to an infrequently used relay in the box will cure all problems.
Or, they are cheap enough to just replace it.
But, this thing sound much more like an electronic glitch.
A weak relay will be there all the time.
Old Sep 26, 2010 | 05:08 PM
dchamberlain
If the Accessory Delay Relay were up front on a 2002, (indeed if the 2002 had a Power Distribution Box with relays up front), then that might be helpful.
Here is the location of the Accessory Delay Relay on a 2002. Bottom center in the diagram.
Old Sep 27, 2010 | 08:40 PM
jc8825's Avatar
jc8825
So I got in the truck this afternoon after work and again, no windows, no radio. This time it fixed itself sooner (within 15 seconds). So this seems to be the relay? It is just a generic relay right? One I can pickup at an auto parts store?
Old Sep 27, 2010 | 09:40 PM
dchamberlain
I think that is most likely the problem.
You can try taking it out and taking it to an auto parts store. I did that here and got that dumb look like something was growing out of my head. But then, I live in the middle of nowhere, with two tiny auto parts stores.
I got an OEM relay at Ford for about $10.
You could also try the relay swap bit, just to be sure. Swap it with something like the fuel heater relay, which isn't terribly critical.
Headviking
May 14, 2017 07:50 PM
Went724
Apr 8, 2014 09:48 PM
miserableloser
Oct 21, 2012 11:25 AM
bulletpruf
Jul 19, 2012 10:59 AM
jc8825
Aug 17, 2010 07:04 PM
