Compression
Old Sep 26, 2010 | 01:20 AM
gw1ngl's Avatar
gw1ngl
Compression
Compression of 1 and 2 are 30 psi and all the rest is 95psi.
its a 4x4 f250 460 1987.
That is best to do?
some said timing chain could be making the others low and a head leak on the others.
Old Sep 26, 2010 | 09:21 AM
96ford250's Avatar
96ford250
id try spraying water on the block when you do the compression test and see if you can see any bubbles coming from the head gasket its doesnt completely rule out a blown head gasket but it might tell you with out tearing it apart
89f150billy
22
Jan 25, 2014 12:12 PM
joelfx4
Sep 19, 2010 03:57 PM
fordberg
Dec 13, 2005 12:51 PM
MontanaFord
13
Jun 27, 2004 01:18 PM
macman85602
Dec 7, 2003 10:57 PM
