Gnarly Dead Spot
Old Sep 26, 2010 | 12:44 AM
saskpwr's Avatar
saskpwr
Gnarly Dead Spot
Today I finally took a look at my carb and noticed a sleeve had pulled out on the front. I put the sleeve back on and immediately after that the motor ran smooth as opposed to running it with a little choke all the time to stop it from dying. But when i got in and started driving the motor just dies off idle when I start to give it gas let alone ease the clutch out. If I rest my foot on the pedal it hesitates for a couple seconds and then it starts revving way too high like 1600-2000 ish rpm. The truck never did this before when it was run with a bit of choke. I'm guessing this is an accelerator pump problem but I'm lazy and don't want to investigate/rebuild a carb I was told was just rebuilt (by the guy who ran it with choke after rebuilding it). The motors a 1963 223 !bbl guessing its a holley 1904 unless they put other carbs on them too. Pics coming soon
Old Sep 26, 2010 | 02:59 PM
66crawler's Avatar
66crawler
If it runs with the choke on that means its not getting enough fuel. So it sounds like a vacume leak.
