I don't know what pin goes to the pigtail sense wire on yours... but if you are getting 12.7 and you got the sense wire going from panel to alternator...
It is the panel.
There are specialized shops that just fixes / repairs / rebuilds instrument panels --- go to them to bench test your panel.
Hey --- long shot... do a complete reset of your cars computers --- just in case it is a electronic glitch.
The alternator warning bulb (if your panel uses one) should be in a plastic holder and clearly visible once you remove the instrument cluster from the car.
It is the same as the lights that light up the panel (at night) and turn signal, high beam, etc.
Go back to the circuit diagram, and you will see the alternator light / resistor is needed to "load" the circuit, hence the 8-9 volt and not full battery voltage.
If the bulb is working but intermittently not making contact.. it can cause all sorts of issues.
I am not absolutely sure that your panel uses an alternator warning bulb --- as some panels now use an LED for that.
So this whole issue may be moot.
There is no "tampering" inside the cluster... don't do that!
I took the bulb out and and put 12v to it and it lite when the bulb reinstalled to the board and plug in to the battery voltage koeo the output is battery voltage at the output pin and both sides of the indicator bulb is battery voltage , I must be doing something wrong if the bulb is the only resistor in the circut.
If you are SURE you measured the alternator exciter wire pin out on the instrument panel (and with the harness disconnected) and it reads battery voltage...
It is time to get that panel to a pro to look at it...
Ive been over wiring schematic a dozen times for the correct pin Im sure Im got it right.....I have caused myself alot of headaches jumping to conclusions an $$$$ so I hope I got it right
One technique to try -- leave the harness on (and risk the fault is further downstream) --- but use a probe to check the wire coming out (rather than just the pin).
You can ID the wire by the color --- and be sure you get that right.
If you are at a shop, sometimes it is just easier to substitute a panel... or bench test the panel.
well I put another board on and same results were found I would like to know in fact that when 12.00v goes into the inst. board that 1-3v would come out of the board to the alternator Im doubting that its the board.
