Ease my mind, please
Old Sep 24, 2010 | 11:11 AM
CampSpringsJohn's Avatar
CampSpringsJohn
The 6637 Riffraff Diesel: RDP 6637 Filter Kit will increase the turbo whistle from the intake side. A 4" Riffraff Diesel: Aluminized Single Exhaust straight pipe will allow some turbo whistle to be heard from the exhaust. It won't be as much as the 6.0, but you will hear some. In my case, a muffler hides all the exhaust turbo whistle. There is a guy that handles the above mentioned products at a very reasonable price, and he really knows the 7.3's!
Old Sep 24, 2010 | 12:18 PM
MR5x5's Avatar
MR5x5
The low end knock at the RPMs you describe sounds like the classic #8 injector knock. If so, you can go a very along way towards quieting it down by doing the mods that eliminate air in the fuel lines and imporve fuel delivery to #8. Specifically I'm referring to the Hutch and Harpoon in-tank mods, some sort of regulated return (search "CCK" for a good, poor man's version) and a Fuel Pressure increase mod (search FPR for a very cost effective method).
-Mike
Old Sep 24, 2010 | 12:38 PM
JonathanN's Avatar
JonathanN
Yup... very typical. In-tank mods and a regulated fuel return will help you out a TON... plus, you get more low-end torque!
Old Sep 24, 2010 | 01:04 PM
PaysonPSD's Avatar
PaysonPSD
As for the "slight shudder" when taking off try regreasing the rear drive shaft splines. May or may not help but it's cheap and easy and most likely needs to be done anyway. LINK Check the splines for abnormal wear while you have it apart.
Good links in my sig for maintenance and mods.
Also check out the Riffraff FRx
Old Sep 24, 2010 | 01:46 PM
flatbeder's Avatar
flatbeder
I agree with make a list of need to do's, and want to do's. IMHO mantience,and safety items should be delt with first then modding the truck. I would start by giving your truck a good inspection and crawl undernenth, and while under your truck look for any leaks or if anything feels loose I.e u-joints, pinion bearing in rear axle. Become familiar with your truck. Then decide if its worth keeping or not.
Old Sep 24, 2010 | 02:10 PM
BrandonT71's Avatar
BrandonT71
-Mike
Thanks Mike, I think thats the info I was looking for or at least a direction to head in. I was guessing that fuel delivery may be an issue, since after spooling her up-n-romping on 'er, she seems to lag on fuel when you take the pedal out of it. If that makes any sense to you guys.
Old Sep 24, 2010 | 02:12 PM
BrandonT71's Avatar
BrandonT71
I'll add this to my to-do's. Thanks for a direction to head in over than bad rearend!
Old Sep 24, 2010 | 02:22 PM
BrandonT71's Avatar
BrandonT71
I have been underneath quite a bit and most look fine, rearend is tight no leaks, u joints seem ok don't clunk when engaged, under side of motor is a bit greasy with very small amount of oil from trans weep, noted last time underneath small coolant leak on water pump inlet elbow- think its just a bad gasket since it is coming from the lower mounting bolt. I'll just keep on keepin' on, and ask q's and knock these things out one at a time. I'll get there, with your help. Any other direction in what to look for in diagnosing and repairing engine knock and shudder would be great.
Old Sep 24, 2010 | 03:34 PM
JonathanN's Avatar
JonathanN
To the OP...
If it's a slight shudder, it can be normal. Supposedly, a slight shudder under heavy acceleration (usually only in 1st for me) is normal... TransGo makes a shift kit that will supposedly cure that. I think I have bigger problems with my trans so I probably will end up getting more into my trans than I really want to...
Old Sep 24, 2010 | 04:09 PM
flatbeder's Avatar
flatbeder
The shutter could be a number of things...The UVCH may have worked it self loose, fix with a .50 mod. It could be your TPS is worn out aswell, and you said if IIRC you had just under 200k or in that nieghborhood? It could be time to start thinking about new sticks. Check your ICP sensor for oil, and the EBPV and tube for crack and soot bluid up.
mtnxtreme800
Aug 14, 2012 07:00 PM
Amilledge8
Feb 25, 2012 05:47 PM
racenitro
23
Jan 25, 2008 01:38 AM
expy37at
Jan 4, 2008 06:09 PM
gustaf
Nov 19, 2005 08:26 AM
