HELP! Does anyone have a 99 Expedition and had the trans fluid changed? (30,000 mi service)
Need to change trans fluid, but don't know which filter to buy,
as I don't know which tranny I have. Apparently, 99s with the larger
330 V-8 had both the E4OD and the 4R100. How can I tell them apart?
Is there a tag or VIN # that will identify the trans? The vehicle is a
4WD and has the tow package, with 9.75"rear axle and 3.73s. Hate to
buy two filters...
Take a look at the Vehicle Certification Label on your driver's door. Under the "TR" heading (#10 in the image seen here) you'll see either a U or an E. U = AOD. E = 4R100.
Knuckles,
Thanks very much for the assistance; the dealer would just tell me to "bring it down", and I that would waste a whole day just to determine the trans type.
Thanks again-
