Sponsored by: Real Truck
oil change question.
Old Sep 22, 2010 | 08:00 PM
WorkhorseF250's Avatar
WorkhorseF250
was talking to a guy the other day about oil changes and he said before a oil change throw 1/2 a can of sea foam in the oil and run the truck for about a 100 kms... my question to you guys is, is this first of safe thing to do and second does it actually help on a high miled engine?
oh got a 2006 5.4l SC f-250 thanks for the opinions
Old Sep 22, 2010 | 08:07 PM
senix's Avatar
senix
personally, I you do regular oil changes at around 3-4K miles or shorter if heavy use then that is better.
This whole extended intervals with oil causes the need for these cleaners.
Old Sep 22, 2010 | 08:10 PM
Speedjester's Avatar
Speedjester
Seafoam is good as well as mystery oil... helps remove sludge..
Old Sep 22, 2010 | 08:14 PM
senix's Avatar
senix
Right, that is what I hear, but my whole it why? If you need to do this to an old motor then I understand.
I would just advise a proper oil change interval and then you never have that issue.
Old Sep 22, 2010 | 08:16 PM
WorkhorseF250
I've kept up on my oil changes and all just i was thinking this might help with the cam phasers ticking... its actually another question i have they seem to act up randomly not sure one day the truck will run smooth and the next day it ticks then it goes away checked all the plugs they are all good not sure if sea foam will help tho
and should the sea foam be added run for 100kms then dumped? i dont do long commutes anymore letting that sit would it be any good for the seals?
WorkhorseF250
Old Sep 22, 2010 | 08:20 PM
WorkhorseF250
the engine has 223000kms on it so its not bad. i got the truck at 123000kms so from that point on its been maintained
Old Sep 22, 2010 | 08:22 PM
senix's Avatar
senix
I suppose in your case it could not hurt. Just follow the directions on the bottle. Go to u tube there are some videos on it.
Speedjester
I agree if you take care and keep up maintenance u shouldn't need it...but a while back I had a sticky lifter and seafoam and mm oil cleared it up ...
