I am in the process of making my own fuel feed lines for the front of my cylinder heads. My plan is to remove both lines (L&R), remove the banjo bolts and the fitting s that are in the fuel bowl. I would like to preorder the stuff from discounthydraulichose.com but am unsure of the thread type adapters needed.
The two banjo bolts will be replaced with 90* fittings with JIC ends and the two fittings in the fuel bowl will be replaced with similiar fittings.
Does anyone know the thread pitch of the banjo bolts and the thread pitch of the two fittings in the fuel bowl. I am pretty certain the ones in the fuel bowl are ORB but not sure about the banjos.
If anyone has a good idea and can share it I'd appreciate it.
