Sponsored by: Auxito
Need Help ASAP Please
Old Sep 22, 2010 | 03:06 PM
wxscoe's Avatar
wxscoe
I have a 2000 SuperCab 150 with 83K miles. It just started making a squeaking/squealing noise from the front passenger side wheel. It only makes the noise at idling speed, taking off from a stop, and when I am coming to a stop. The squeaking/squealing noise will let up, and it makes a faint clicking noise. Once up to speed, I cannot hear either of the sounds. Thanks in advance for any suggestions.
Old Sep 22, 2010 | 03:22 PM
KingRanchMan02's Avatar
KingRanchMan02
Have you checked the brake linings?
Old Sep 22, 2010 | 03:30 PM
wxscoe's Avatar
wxscoe
King,
Yeah, I checked out everything with the brakes. It all looked fine. Just went out and looked again, I'm thinking it's the cv joint, there's grease around hub behind the wheel.
Old Sep 24, 2010 | 11:27 PM
Podaso's Avatar
Podaso
If it's the CV joint and there's grease around the hub, then I'd assume that the grease would be 'flinging' all over the place from the wheel/cv joint spinning. When I replaced mine, it was making a 'whining' noise. Have you checked the bearings/hub (whichever yours has)?
Old Sep 25, 2010 | 06:57 PM
wxscoe's Avatar
wxscoe
I don't see where any grease was flying out anywhere. I haven't checked the bearings/hub yet, haven't had the time to.
