Suspension question
Old Sep 22, 2010 | 01:27 PM
allwthrrider's Avatar
allwthrrider
Suspension question
Hey all heres what I did, I had a 1970 28 ft weekender Motorhome on a F350 camper special Chassie, I swapped the rearend including springs over to my 1967 F250 Camper Special then I swapped the I beams with springs over to the 67, I like the 6in extra lift but my front tires are now making a major V sign, the springs from the 70 are about 4 inches longer and a 1/3 bigger in diameter , does anyone make brackets to extend the pivot end of the I beams down or is my only option to cut the coil springs down some, I've measured the brackets and the distances are pretty much equal between mounts and spring perches, Both vehicle's have 390FE the 67 has a C4 Trans the 70 has C6 that I'm changing over next, any suggestions,,,, thanks
Old Sep 22, 2010 | 03:32 PM
jowilker's Avatar
jowilker
Try putting the original springs back under the truck.
John
Old Sep 23, 2010 | 01:18 PM
allwthrrider
More info, was out this morning looking things over again, found that the coil spring tower from the 70 sits 3.5 in higher above the frame than the 67 also the coil springs from the 67 uncompressed are the same length as the 70 springs on the truck now with full weight on them so should I just cut a few coils off the 70 springs or change out the coil towers which will be a much more involved job, I know I can't keep the lift but I sure like the way it looks
