I'm interested in a 2001-2004 f250 super duty 4x4 with a 5.4l but am concerned about the spark plug issue. I recently asked a ford dealer about the issue and this was there reply; I was wondering if this explanation holds any merit ? The dealer said there is no problem but the 5.4l must be decarboned at the dealer before plugs are changed as when the plugs are removed the carbon is so hard that it damages the threads as the plug is being removed if not decarboned first.Then the plugs must be properly torqued(makes sense).How much of an issue is this and is there one year in the range mentioned above that is more reliable than another? Thanks in advance for your replies!
What plug issue are you referring to? The earlier 5.4's had issues with blowing plugs out because of insufficient thread count on the plugs but this was fixed in the year string you listed. Also, the 3v engines have plug issues but that's not going to be in the years described either.
It wasn't fixed for those years, sometime in '03 in the F150 they doubled the thread count, I've never heard if they ever did it for the SD's most likely '04 at least got the 8 thread heads Since the SD's were a year behind the F150 I'd doubt the '03s got them but it is possible. I've never heard the carbon excuse for the spitting plugs but other places than the dealer definitely do the "decarbonizing", Napa service centers or example do the motorvac. anyway when my first plug spit the plugs had been in for a good 40K miles so I doubt any carbon ruining the threads 40K ago caused the problem.
My guess also is that the combustion chamber shouldn't be burning that dirty to build up that kind of crap on the threaded area. I do vaguely remember something about carbon and plug threads but I think it was on the 3V's, and again hard to believe they would burn that dirty.
Just done the plugs and boots on my 03' and it has the updated thread count. The build date on my truck is either Oct. or Nov. 02' if I remember correctly.
I'm not familiar with the 5.4l that much.This forum had a thread that said the 2003 5.4l had more threads put in the head; is that so? I'm not aware of what year started the 3v .The bottom line is that I'm shopping for a new used truck in around the years mentioned 2001-2004 and would like some advice on the most reliable of those years.If there is any other issues with the super duty 4x4 that I should know of ;the info would be appreciated.
Ps : Just out of interest ,the reason I'm looking for a Ford is that my 2001 GMC SIERRA 2500 just burned to a crisp due to an unknown electrical problem! Truck parked for days then I come home and the truck bursts into flames. I'm changing brands with a wary eye.
I want to make sure I give you the right information but from what I'm gathering is the 03'-04' had the updated plugs and the 3v engines started sometime in 05' production time frame. I hope someone with more knowledge with this chimes in to confirm this for you and I.
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
I had a 2003 5.4L, and finally changed my plugs at 105,000 miles. Carbon build-up??? Never heard that one before. Sounds like the dealer wants some money from you. Anyway, I never had any problem with spitting plugs, did not have any issues changing them, and that truck was never in the shop for anything the entire time I owned it. Had 125,000 miles on it. I sold it to a guy down the street to tow his travel trailer. He loves it, and uses it often. Still a great looking truck, and I miss it a lot. If I didn't need the diesel with my new 5th wheel, I would still have it. It was, and is, a great truck.
My son in-laws 05 f150 4.6l blew a plug about a year ago. I don't remember what plug it was but Ford replaced the whole head. I also can't clarify if he had the additional threads but i would assume so being an 05. This also leads me to believe that it hasn't eliminated it.
As far as the 5.4l 3v and 2v as well is the problem was not blowing plugs but plug breakage on removal. The assumption is that excessive carbon buildup in the plug well caused the two-piece plug to break off in the head. So in essence the problem was more with the 2 piece shell plug design. They have since designed a 1 piece shell plug.
I had my plugs changed on my 06 at 60k and the dealer broke 4 (2 piece shell). I had them install the newer 1 piece plug. I am planning on changing them at 100k.
