MAP SENSOR GRAY IN COLOR
Old Sep 21, 2010 | 06:20 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question MAP SENSOR GRAY IN COLOR
Where is the best place (price) to get a MAP sensor. I always read that the gray in color (F4TZ-9F479A - 3 Bar.Motorcraft PN (DY708) was the correct one, and mine was gray color, so I was peaceful, but the other day I checked the number of it and it has the F4TF-9S480-AA, what is supposed to be black in color, oh my mistake, and as I have having lost of power in high altitude and bad MPG and reading that with the black in color it could be happens, I was believing that my issue was caused for other thing, but now, I’m almost convinced that the “wrong” MAP sensor is the culprit, so I’m going to buy the correct gray in color and number, and that’s the reason I’m asking. I have searched in the internet and got prices between $ 103 to $165.<o></o>
<o> </o>
Thanks in advance.<o></o>
Old Sep 21, 2010 | 07:07 PM
pjwoolw's Avatar
pjwoolw
Here ya go pardner.
Old Sep 21, 2010 | 07:22 PM
fordpride's Avatar
fordpride
I have an extra PM me if you want it
Old Sep 21, 2010 | 08:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Originally Posted by pjwoolw
Here ya go pardner.
Pete, yes thats the article I read. Thank you.
You will have a PM. Thanks.
Old Sep 21, 2010 | 08:39 PM
Hussler's Avatar
Hussler
Jose, what does your scan gauge indicate on boost? Find a safe place then accelerate to about 20 MPH and floor it to about 55 - 60 MPH. On my pretty much stock truck I can get 16 PSI and don't expect anything more without additional mods. I have the same as yours F4TF-9S480-AA and it looks black because it's encased in a black bracket and has a black plug. I've researched F4TZ-9F479A against the other number and they show up as the same part, just different numbers. Also I've benched tested my MAP sensor under different pressures and the output correlates to the proper frequency output per pound of boost. The above test, peddle to the metal should give you some indication if it's working properly or not.
Old Sep 21, 2010 | 09:28 PM
fordpride's Avatar
fordpride
Hussler i have the same one on my truck and this is my extra one
Old Sep 22, 2010 | 10:17 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Jim, Yes both numbers looks or are the same color as I understand, but in the article that Pete linked you can see that the performance is different between them . Im going o to the test what you mention. normally the scan gauge reads negative numbers at idle (-2, -7)
Thats the same I have. Mike you have a PM
Thanks to all
Old Sep 22, 2010 | 12:59 PM
884x4broncoII's Avatar
884x4broncoII
im bookmarking this, i need to replace my map sensor, i was having some running problems and unplugged my map sensor and i got my power back and the truck is running much better.
Old Sep 22, 2010 | 10:35 PM
oldbird1965's Avatar
oldbird1965
Jose, I just replaced mine and the numbers listed above are the same as mine were. The old number and the new.
Old Sep 23, 2010 | 08:15 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
OK, but what number did you order?
the correct one according with the article F4TZ-9F479A - 3 Bar.Motorcraft PN (DY708) or the F4TF-9S480-AA ?
wpnaes
S. California Chapter
133
Nov 15, 2014 09:21 PM
Truckandute
Aug 28, 2014 01:42 PM
Jesser02EX
35
Jul 14, 2014 12:17 PM
myakkacracka
Mar 17, 2014 07:35 AM
ex90ranger
Electrical Systems/Wiring
Dec 26, 2012 07:33 PM
