89 f150 idle
Old Feb 20, 2003 | 07:25 PM
bigcj39's Avatar
bigcj39
89 f150 idle
89 f150 6cyl...wants to ilde down to 500,600 and realy rough up untill about 1400 rpm ,no codes,horriblle gas millage.put in new plugs .(5speed manual trans)
Old Feb 20, 2003 | 10:13 PM
fastf150's Avatar
fastf150
89 f150 idle
everytime someone does a tune up due to bad gas mileage they usually forget a very important part which is the o2 sensor. If you have bad gas mileage and no trouble codes, then try replacing the sensor and maybe the fuel filter as well. But def. the o2 sensor as this tells the computer what the end result is ogf all the air and fuel going into the engine.
