1978 - 1996 Big Bronco
won't turn over
Old Feb 20, 2003 | 07:22 PM
scootin's Avatar
scootin
won't turn over
my '94 302 won't turn over!@#% The rig was running fine this afternoon, but now she just won't turn! I'm getting all lights, access, etc., but nothing happens when the key gets turned. No clicks, whirls, nothing... ANy ideas?
Old Feb 20, 2003 | 07:48 PM
BroncoRoadKill's Avatar
BroncoRoadKill
won't turn over
Hi, You might start by checking the solinoid (switch) on the right fender. Get somebody to turn the key while you tap on the switch with a wrench or small hammer, just tap, don't hit hard. If that doesent work then maybe look at if the ignition wire at the switch gets hot when the ignition switch is turned. It could be your ignition switch or maybe a fuse or relay.
Hope this helps any, good luck.
_Clints
Old Feb 21, 2003 | 12:09 PM
xuare's Avatar
xuare
won't turn over
Do the lights, etc. stay on when you turn the key to run the starter?
If yes, probably mechanical (solenoid, starter), or possibly a loose positive lead from the ignition to the solenoid or starter.
If no, you may have a bad negative ground on the battery. The negtavice cable can't handle the ampage of the starter but works fine with lighter electric loads because it's only making partial contact. Clean both ends of the neg cable and where the ends connect to ( - battery term and block grounding bolt) Tighten the cable down tight on both ends and try starting again.
Old Feb 21, 2003 | 01:25 PM
scootin's Avatar
scootin
won't turn over
Problem solved - It was the solenoid. Just replaced that for rather cheap and voila!
Thanks for the info fellas - another come through from this forum.
