knocking???
Old Sep 21, 2010 | 02:23 PM
Speedjester's Avatar
Speedjester
knocking???
Well started the truck this morning and heard a Knock that lasted about 5 to 10 seconds...Is this a bad thing... Could it be rod knock... I will tell you it was close to empty and the temp was about 50*F this morning and it did drop into the high 30 over night... How could you tell the diference between rod knock and diesel knock????
I run 15w40 motorcraft oil and filter just changed less than 400 miles ago
Old Sep 21, 2010 | 06:26 PM
Sarge261's Avatar
Sarge261
Its hard to say without hearing it. Every diesel truck makes its own noises, I think it even states that in the owners manual. I know my truck is a little more noisey on the colder mornings here, but its not a knock. You would know if your truck had a rod knock it would be real noticeable in a diesel engine.
Have you ever considerd switching to a 5w40 synthetic diesel oil. I run Rotella T6, and my cold weather starts are way better, and cold weather noise is not as noticable.
Sarge
Old Sep 21, 2010 | 07:08 PM
Speedjester
I just run the oil recommended by Ford.. It says to run 15 w 40... Wondering if fuel quality could have anything to do with it... Brought diesel at this real out of the way gas station and never added the diesel Kleen... Used the mechanics stethoscope and got a nice whooshing noise from the pan... No knocking after filling up and driving it all day (checking on it periodically).. Would it be safe to assume rod knock on a diesel would be pretty pronounced... How common is rod knock on a 6.0.. And is there a way to differentiate between rod knock and diesel knock... What can cause rod knock..
Any thoughts would be appreciated... Thank you
Old Sep 21, 2010 | 07:32 PM
cheezit's Avatar
cheezit
really rod knocks and volume depend on how bad the knock is. 6.0's are not knowen to toss rods out to often.
how do you tell the differance... thats a hard question. I just know.
Old Sep 21, 2010 | 07:44 PM
Speedjester
Cheezit.. Can bad fuel and tank almost empty cause a knocking(first thing in the morning).. I would of isolated the sound if I had more than a few seconds before it disappeared.. AI would also think the knock would get worst with heat and the oil thinning out.. But since I checked it using one of those(don't laugh) stethoscopes I couldn't find or hear the knock???(nice whooshing sound from the pan and the general lite tap from the side of the block...
Wouldn't rod knock get worst after it heats up???...
Old Sep 21, 2010 | 07:47 PM
cheezit's Avatar
cheezit
fuel knocking is going to happen with low fuel pressure, or anything like gelling. It can also be caused by low battery voltage or ficm concerns.
rod knocks dont always get worse... but they never get better.
Old Sep 21, 2010 | 07:52 PM
Speedjester
Cheezit what I meant is wouldn't rod knock become more noticeable when the engine heats up and the oil thins... Instead of disappearing within 5 seconds of start??? So poor quality of fuel will not cause diesel knock??
How are the bottom ends on these motors???
Old Sep 21, 2010 | 08:03 PM
cheezit's Avatar
cheezit
poor fuel quality, fuel mixed with water or gas will as well.
a rod knock will not really change much with temp unless it really bad.
the bottom end of a 6.0 is about as good as they come. Very few lower end issues that cant be explaned. I dont think I have ever hung a set of bearings in a 6.0. No rods either.
Ive seen one broken crankshaft, that one was caused by a bad case of dumba$$
Old Sep 21, 2010 | 08:14 PM
Speedjester
Cheezit.. So if it were rod knock would it disappear after it runs for 5 seconds??? Or Should it be always there... It just did it this morning for the first time for 5 seconds on initial start up.. After that I never heard it again??
Old Sep 21, 2010 | 08:16 PM
cheezit's Avatar
cheezit
a rod knock is a rod knock and in 99% of the cases it will still be there. summer winter, fall, etc... all the time
Old Sep 21, 2010 | 08:21 PM
Speedjester
Cheezit. Thank you for taking the time to help me with this...I appreciate it....
Old Sep 21, 2010 | 08:22 PM
cheezit's Avatar
cheezit
anytime.
Old Sep 22, 2010 | 07:03 AM
Sarge261's Avatar
Sarge261
And the master has spoken young grasshopper
Old Sep 22, 2010 | 07:13 AM
Speedjester
Thanks Sarge.... I appreciate your help also... stay safe
Old Sep 22, 2010 | 07:20 AM
Sarge261's Avatar
Sarge261
Thats why were here...and your welcome.
