Sponsored by: Real Truck
Rear end hopping
Old Sep 20, 2010 | 06:33 PM
Northern Caveman's Avatar
Northern Caveman
Rear end hopping
what could be causing my rear end to hop while driving on the highway it dosent happen all the but enough that it concerns me
my truck is a F250 Superduty 4x4
Old Sep 20, 2010 | 07:10 PM
bit breaker's Avatar
bit breaker
bumpy road, bad shocks, weak springs, unblanced wheels/tires, bent wheels, empty bed/light load, bad axle bearings, many numerous things.
i would try putting some concrete or sand bags back there to see if that helps.
Old Sep 20, 2010 | 09:32 PM
Northern Caveman
ok well i am getting my winter tires put back on here soon see if the fixes it i hope it does
Old Sep 21, 2010 | 04:20 PM
Northern Caveman
it was my crappy summer tires were unblanced
Old Sep 21, 2010 | 04:27 PM
ak-angler's Avatar
ak-angler
Good to hear you found the problem. And thanks for reporting back.
Old Sep 21, 2010 | 09:30 PM
big_stever's Avatar
big_stever
i would check the fluid levels on the rear end. my 01 was doing it too and i ignored it till finally it locked up and the entire rear of the truck was close to a foot off the ground. when i finally got it back to my friends place which was the nearest the rear dif was smoking. when i got the cover off there was no fluid left at all and i pulled around 5 lbs of metal out of there. the rear carrier was destroyed and so was the ring and pinion.
Old Sep 21, 2010 | 10:37 PM
Northern Caveman
big steve thanks for givin me the heads up on that i will be checking that tomorow after work the hop stoped after i put my winter tires on today but i am still going to check that
skoveng
Jul 4, 2013 01:16 PM
brokeisnojoke
Jun 29, 2011 10:29 AM
fisher1995
Mar 9, 2007 10:28 AM
GHog
Offroad & 4x4
17
Aug 14, 2005 10:13 PM
GHog
Aug 7, 2005 12:51 PM
