Rough Idle/Surge???
Old Sep 20, 2010 | 12:34 PM
Bowie's Avatar
Bowie
Rough Idle/Surge???
On my way to work this morning the truck was Idling a little rough. Almost like it was a slight surge and the truck was not idling as smooth as normal. It was only happening when I was stopped. Any idea? CPS? I had a 1/4 tank of gas and it has been 3 weeks since I changed the fuel filter. It was happening after the truck was warmed and when it was cold. It is not cold here like 60 degrees. Thoughts????
Thanks
Kyle
Old Sep 20, 2010 | 05:52 PM
F350-6's Avatar
F350-6
How's your oil? Did you try switching tunes to see if the problem happened in all tunes?
Old Sep 21, 2010 | 09:24 AM
Bowie's Avatar
Bowie
I changed the oil the same time I changed the fuel filter about 3 weeks ago now. Could it be the CPS? Or does that sound like bad fuel? I had ran the engine down to about 1/4 tank, it did start as I was facing down hill at a pretty good angle. It did seem to continue though as I got down to the flat. I did not notice anything out of the norm as I started to move though.
What does the truck do as the CPS goes out? What about bad fuel?
It was happening in stock mode and did not try it in the other modes.
coalnation
Large Truck
Mar 19, 2015 07:19 PM
jmerrill89
Feb 11, 2011 08:32 AM
ARK Ranger
Jan 14, 2011 02:30 PM
astone
1997 - 2003 F150
Nov 24, 2008 04:35 PM
93angryranger
3.0L V6
Mar 13, 2006 09:09 PM
