2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
air suspension pump noise
Old 09-20-2010, 10:03 PM
bjtor's Avatar
bjtor
bjtor is offline
Has anyone had excessive noise from their air suspension compressor?
I have an 08 EL Limited and the pump for the air suspension has gotten really loud. It went on when I was sitting in my driveway and my wife (who was inside the house) asked me if that horrible noise was from my truck?
Sounds like something is loose and vibrating when it turns on. The pump clearly is working, as the car is level, but it sounds like I am running a table saw.
My Ford dealer couldn't make the thing turn on, so has no idea what to do. Short of replacing the motor, or at least removing it, not sure what to do. Any thoughts would be appreciated.
Old 10-04-2010, 02:11 PM
dballs's Avatar
dballs
dballs is offline
Mine(same year, same model) is noisy also, sounds like it is getting worse. Scheduled to take it to dealer next week. Will post the results.
Old 10-17-2010, 05:14 PM
bjtor's Avatar
bjtor
bjtor is offline
pump noise
any luck with this problem?
thanks a lot
bjtor's Avatar
bjtor
bjtor is offline
Hi,
any luck at your dealer on this problem?
thanks for any ideas
Old 10-25-2010, 03:18 PM
2trux's Avatar
2trux
2trux is offline
When mine started to get really loud I replaced it. When I took the old one off I noticed the rubber grommets that are supposed to isolate the vibrations were shot. I think the pump frame was hitting the inner fender. You might try checking that and if needed add something to isolate the pump better. Let me know if this fixes it. I kept my old pump incase I have a problem with the new one.
Old 12-01-2010, 10:06 AM
bjtor's Avatar
bjtor
bjtor is offline
Update on the air suspension pump
the Dealer finally replaced the pump yesterday (after four visits) and it is now as quiet as it was when new.
not sure what the problem was, but it clearly needed a new pump
Old 02-20-2011, 08:10 PM
dballs's Avatar
dballs
dballs is offline
Sorry never posted an update.....was away from the forum for some time.
I took mine in and the dealer replaced the pump. Considerably more quiet but I can still hear it kick in, but nothing like before when it sounded absolutely terrible.
Old 02-20-2011, 09:11 PM
bjtor's Avatar
bjtor
bjtor is offline
sounds like your experience is the same as mine- much quieter now but i can still hear it kick in.
thanks
Old 02-21-2011, 07:16 AM
ford-speed's Avatar
ford-speed
ford-speed is offline
Yea...mine isn't that loud. I'm going to get an alignment once I put my rims on. I'll just ask the stealership to take a peek at it.
Old 09-08-2011, 01:15 AM
acollins24's Avatar
acollins24
acollins24 is offline
I already replaced the whole air suspension system with something from the aftermarket after the stock one also made that loud hissing sound regularly. I think the stock air would have issues with the pump after a few years. In fairness though, at least ride quality wasn't affected even with that issue.
baylormcdaniel
2004 - 2008 F150
01-10-2017 08:21 PM
HiZ
10-24-2016 10:04 PM
expydaddy
1997-2006 Expedition & Navigator
05-28-2013 11:08 PM
jdhdafd
02-28-2010 09:41 AM
navigatorade
12-26-2007 06:27 PM
Quick Reply: air suspension pump noise
