Damper key removal
Old Sep 19, 2010 | 05:04 PM
skeeter9's Avatar
skeeter9
Damper key removal
ok the timing chain housing gasket is no good ive removed the water pump etc. I have also removed the harmonic balancer etc... now there is the raised "nipple" or groove that is on the crankshaft how to i remove it so i can remove the pulley spacer... i believe its referred to as a damper or damper key... i need to get the timing chain housing off and replace the gasket ASAP
