HELP!!! 03 Expedition 4.6L (P2198 & P0306) + Blinking CEL
SEARCHED EVERYWHERE!
Firstly, I maintain my truck meticulously. All routine maintenances are performed and thats why this is so upsetting. 6 months ago my truck started hesitating and having intermittent loss of power. I ended finding out it was a vacuum leak on the PCV hose that was straight up burnt through. I replaced it, cleared the codes and it ran like a champ. Now for about the passed month I've noticed the SAME symptoms. It started out with light hesitation and a misfire here and there but eventually has gotten to a serious hesitation (mostly under 3K RPM's) and a lot of misfires. I couldn't check the code however because even though the truck was running TERRIBLE and I mean like stalling terrible, there was no CEL. Naturally I sprayed carb cleaner everywhere looking for a vacuum leak like before and nothing. No leaks. So then I cleaned sensors and my EGR valve and no change. Next I replaced ALL 4 o2 sensors and no change EXCEPT, I finally got a CEL. Checked the codes and I have:
P2198
P0306
Obviously I've been able to find what they mean individually but I'm not sure if one is causing the other or what. After spending $200 on O2 sensors I really don't want to take it to the mechanic and spend more. I can buy and install parts fine but I don't want to buy every possible part in the world to fix it. Please help me diagnose this gentlemen. My girl and my 5 year old get around in this thing and the last thing they need is for it to stall. Thanks!
RECAP OF WHAT IVE DONE IN THE PAST 3-4 MONTHS (MAINTENANCE INCLUDED):
Cleaned sensors
Cleaned EGR (Verified not stuck)
Replaced all O2 sensors
Replaced fuel filter
Replaced PCV
Replaced Spark Plugs
Obviously oil, filter etc.
Thanks in advance!
P2198
P0306
Cleaned sensors
Replaced PCV
Thanks in advance!
I suspect the 306 misfire is causing the 2198. Swap the spark plug in cyl #6 with cyl #5. Swap the coil for cyl #6 with cyl #7. Swap the fuel injector in cyl #6 with cyl #8. Clear rhe codes and drive it to see if the CEL comes back on.
If the CEL indicates cyl #6 you probably have a vacuum leak.
If the CEL indicates the misfire has moved to cyl#5, #7,or #8, you'll know which item is causing the failure.
If no more CEL, be happy.
dszal
1997-2006 Expedition & Navigator
18
02-23-2016 08:51 PM
