Doors/Ignition 1 Key? Possible?
Old Sep 18, 2010 | 04:33 PM
muddyforeman's Avatar
muddyforeman
Ok, I have a 97 250hd. At one point we had to replace the steering colum as the original wore out. Along the years, a few lost sets of keys, and now, all I have is a key to the ignition, not the doors. I've reset tumblers a few times on other vehicles, but the Ignition Key I have now, will not even attempt to go into the lock cylinder.
I even looked at a set of replacement cylinders from work (Advance) and pulled the tumblers on it, and my current key will not work at all for those cylinders.
Is there an earlier year set to get that will allow me to rekey my ignition key to it,
Any help will be appreciated!
Old Sep 18, 2010 | 04:56 PM
raystankewitz's Avatar
raystankewitz
Are you sure you have the right year door cylinders? Sometimes the catalog is wrong on what fits what, that's why I ask. A competent locksmith can re-pin the existing (original) cylinders to match your ignition key if the keyway/key warding match. Or look at the earlier or later cylinders.
As an example, my '97 250HD and my '00 E250 work van have the same warding.
Hope this helps,
Ray
Old Sep 18, 2010 | 07:09 PM
kentuckyredneck's Avatar
kentuckyredneck
Someone correct me if I'm wrong, but couldn't he just buy a set of door and ignition cylinders from LMC? Sounds like the best bet to me.
Old Sep 18, 2010 | 07:19 PM
muddyforeman
I am seeing those seperate, but I'd like to have one key do both,, The way it was when it was new
Old Sep 18, 2010 | 08:10 PM
kentuckyredneck
well one of my catalogs had them. It may have been NPD. I couldn't find them on LMC either.
Old Sep 18, 2010 | 08:13 PM
ichabod40's Avatar
ichabod40
NPD sells sets with one key.
Old Sep 18, 2010 | 09:04 PM
93MARKIII's Avatar
93MARKIII
the front of the key is what works the ignition, the back part works the doors.....if you had an old door key, and new ignition key, locksmith could grind you one from them to work both, you may need to pull the door cylinders and have a key made to match, or better yet, have them re-pinned and make a whole new key that matches since you have some old keys out floating around...
Kwikkordead
141
Apr 26, 2020 07:10 AM
Dean06919
Apr 30, 2016 01:14 PM
jhobbs26
Dec 26, 2014 08:20 AM
Duckmang
Dec 20, 2014 03:15 PM
jtindale
Sep 8, 2012 11:05 PM
