Sponsored by: Auxito
knock sensor help
Old Sep 17, 2010 | 04:42 PM
mikebue's Avatar
mikebue
knock sensor help
so, after doing a little bit of reading, i think that the knock sensor is either bad or causing my motor to run badly. can someone please tell/show me where the plug for the knock sensor is on a 1997 5.4?
Old Sep 18, 2010 | 12:56 PM
Bluegrass 7's Avatar
Bluegrass 7
Mike, I don't know where you have been reading but on an F150/250 5.4, there is no knock sensor used unless it was a special application.
For help, discribe your issue and any codes set.
On knock sensor use, usually on a Mass Air system, no kock sensor is needed.
On Speed Density control systems, a knock sensor was very often used but that system has been obsolete for most of Ford's gas engines for quite a number years.
What does a knock sensor do?
It's use detects spark knock/ping due to over advanced ignition timing per engine loading and gas quality, and feeds back this signal to the computer as a way to retard igniton timing and reduce the knock below the danger point.
Mass Air control systems have so much control that a knock sensor is not normally needed.
Old Sep 18, 2010 | 01:03 PM
jgeese's Avatar
jgeese
Didn't know that Bluegrass! No knock sensor, who da thunk...
