6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
drain water seperator
Old Sep 17, 2010 | 04:57 PM
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
I just had to change my sensor, put little grease on o ring, make sure to snap in tight, if not you will get a fuel leak!
Old Sep 18, 2010 | 09:41 AM
StanleyZ's Avatar
StanleyZ
Originally Posted by Bounds-Electric
I just had to change my sencer, put little grease on o ring, make sure to snap in tight, if not you will get a fuel leak!
Just for grins and future considerations, where is the sensor located? Tex, don't leave us hanging, let us know if the filter fixes the problem. Thanks guys. Stan
Old Sep 18, 2010 | 04:39 PM
Bounds-Electric
FORD USER
Just for grins and future considerations, the sensor is on the bottom front side of the Fuel conditioner (bolted to frame under driver side door) right below the housing were low pressure fuel pump is, back side is filter, rear of it is water drain, Small push in conector 2 wires,
__________________
Old Sep 18, 2010 | 06:04 PM
StanleyZ's Avatar
StanleyZ
Thanks, and here are some grins
Old Sep 19, 2010 | 07:39 AM
Bounds-Electric
FORD USER
Future considerations I will let you know if it works but I have to get some water in fuel!
Hope that takes some time!
Old Sep 19, 2010 | 04:05 PM
wildcrasher's Avatar
wildcrasher
Hello everyone, I am new to this forum and to having a 2008 f350 with the 6.4. I am having the same "drain water in fuel" light coming on problem. Took it to the dealer and they replaced the water seperator module part number 8c3z-9b249-b. I am still having the same problem and now they are saying they have to drop the tank, etc.. to do a fuel test. Which of course will be an addtional charge. From everything that I'm reading they should have replaced the black water sensor that is below the fuel pump. Does anyone know where to get one (part number?) and directions on how to replaced it? Any help would GREATLY be appreciated! Thank you in advance
Old Sep 19, 2010 | 06:33 PM
Bounds-Electric
FORD USER
Have you drained and looked for water?
Old Sep 19, 2010 | 06:56 PM
wildcrasher
Yes I have multiple times, I've let it set overnight with no separation. I'm thinking it must be the sensor based on the different forums ive looked on.
Old Sep 19, 2010 | 07:24 PM
Bounds-Electric
FORD USER
_______I think they changed the drain only!
Sensor Ford Part #8C34-9C264-AA
WIF Sensor two bottom tabs must point down!
Old Sep 19, 2010 | 07:56 PM
Texas450's Avatar
Texas450
Hey guys I replaced the sensor on sat. And drove to dallas today with no problem! The old sensor was full of gunk. Worried my injectors might look the same. Easy cheap fix...when you buy the part from ford it comes w directions
Old Sep 20, 2010 | 08:09 AM
wildcrasher
Thanks guys. I just bought the sensor at the dealer and will replace it tonight. I'll let you know what happens.
Old Sep 20, 2010 | 03:47 PM
wildcrasher
Great news!! the sensor was gross so I replaced it. Drove around all day and the light never came back on. Now I'm trying to get some money back from the first dealer who said that it wasn't the sensor but the module. It's pretty apparant that they were wrong. $384.00 later...... called them and they said too bad, so now I've filled a report with ford motors and the BBB. If you are in east TN DON'T go the the ford dealer that starts with "L"
Old Sep 20, 2010 | 03:53 PM
  #28
senix's Avatar
senix
That is what I would do. I had a dealer one time sell me an extended warranty, then when I had a repair they wanted me to pay and file with the warranty co for my money....not gonna happen.
Ford came thru though and set them straight.
Old Sep 20, 2010 | 05:01 PM
  #29
Bounds-Electric
FORD USER
[QUOTE=Texas450;9347235]The old sensor was full of gunk. Worried my injectors might look the same!
You have another filter up line before injectors!
Old Sep 20, 2010 | 05:07 PM
  #30
ChargersFanInCO's Avatar
ChargersFanInCO
[quote=Bounds-Electric;9350160]
Thank God (or the engineers) for that one...
OP, if you think your injectors might look like that, it's a good time to run a few tanks with a biocide, followed up by a good injector conditioner like Diesel Kleen...(Yes, I use Diesel Kleen religiously, but I don't sell it or get any money from them)
