6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
front end high
Old Sep 16, 2010 | 07:40 PM
KevinAH's Avatar
KevinAH
front end high
I just purchased an 08 F250. The front end is leveled with a 2 or 2.5". I cannot tell if the rear is any different than it was from the factory. It has appeared to sort of sag in the back. When I loaded my trailer it sagged even more. I added air bags and now it just stays in the same place as it was without the trailer. I decided to measure the distance from the ground to the fender on all sides. The fronts are exactly 3/4" higher than the back. This bugs me, how do I get it exactly level or just slightly higher in the back?
Old Sep 16, 2010 | 08:12 PM
StanleyZ's Avatar
StanleyZ
I guess you've already tried inflating the air bags.
Old Sep 16, 2010 | 08:31 PM
KevinAH's Avatar
KevinAH
Yeah, I had 30lbs in them. I inflated to 45 and no change. I was hoping that would make the difference.
Old Sep 16, 2010 | 09:33 PM
nomorecummins's Avatar
nomorecummins
Have you thought about just removing the leveling kit? I have a 2" leveling kit on mine, and it sits fine. Although I had to replace the front two shocks because they were not long enough for the kit.
Old Sep 16, 2010 | 09:38 PM
KevinAH's Avatar
KevinAH
I would probably have a problem with my wheels and tires. 325-60-20
Old Sep 16, 2010 | 09:50 PM
StanleyZ's Avatar
StanleyZ
I would guess ypu could put 1 inch blocks on the back without screwing up anything.
Old Sep 16, 2010 | 10:14 PM
KevinAH's Avatar
KevinAH
I wondered that exact thing but when I looked back there, it appears there is a block in place already, which I would have to guess; that is how it came off the lot. If that is a 2" block, without stacking onto that, it would be just fine with me if I could find a 3" block which is probably not available. I'll make a couple calls tomorrow to see what I can find.
Old Sep 17, 2010 | 03:49 AM
R-T0r21on's Avatar
R-T0r21on
F-350 rear spring blocks should fix you up.
Old Sep 17, 2010 | 05:19 AM
senix's Avatar
senix
sounds like they wanted to do a leveling kit...but forgot the rear. They should have done a add a leaf to the rear in conjuction with the front leveling.
A 1" add a leaf is in order. That will also require new u-bolts.
Old Sep 17, 2010 | 06:29 AM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Blocks are missing...
Originally Posted by senix
sounds like they wanted to do a leveling kit...but forgot the rear. They should have done a add a leaf to the rear in conjunction with the front leveling.
The Add-a-Leaf would work but I think the kit wasn't fully installed. I put this kit in my '08 F250 and it came with (I believe) 4" factory style blocks with the bump stop platform.
Ford F250 Super Duty SST Hybrid Lift Kit: 2008-2010, 4WD Only - 2.5"/2.0"R
They give you the additional 1" you need to level the truck and I have not experienced any wheel hop/axle wrap because of them. If you call ReadyLift, I'm sure you can buy just the blocks.
Old Sep 17, 2010 | 12:53 PM
KevinAH's Avatar
KevinAH
Thanks for all the info. It looks like I'll be adding a leaf and new U bolts.
Old Sep 20, 2010 | 10:55 AM
Chuckthetruck's Avatar
Chuckthetruck
When adding the SST Lift Kit with 37", has anyone experienced wheel rub when making turns? The SST company specifies that using a 37" tire size on OEM rims will allow for enough wheel clearence. I have been looking at lift kits for a while but dont have the coin. These seems to be an alternative. Also, the shock extension bracket, does anyone recommend purchasing a longer shock as an alternative for the shock bracket? Dont know much about this product, interested in obtaining additional info. Thanks
Old Sep 21, 2010 | 07:15 AM
jimd1050's Avatar
jimd1050
Shocks...
I'm not sure about the SST kits - I bought a ReadyLift 2.5" Kit but still have my 35's on so can't answer that part of the question. I should have 37's on before the snow flies though. I did however, order new shocks - I didn't like the look of the extension brackets or the feel of the stock factory shocks. I purchased longer Rancho RS-9000's for all four corners. They ride great - not too stiff but not too soft either and they're adjustable to boot. Hope this helps...
