7.3/ZF5 Part Out
7.3/ZF5 Part Out
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: TX
Engine: Part suitable for diesel truck
ZF 5 speed- this is a 2wd transmission with a fixed yoke output with a 7.3 bellhousing. And if you're not quite sure which transmission it is, its the granny low'd & overdriven 5 speed that you know you need to replace your tired automatic with, or to upgrade that old 4speed. Transmission shifts smooth, spins freely, feels to be a great transmission $450
Injection lines- Unbroken, appears to have not had any leaks $80 for the set, or $15 each
Exhaust manifolds- Unbroken, good shape- $75 for both
Injection pump- $150
Heads- $65/each
Fuel filter plate & brackets- $50
Alternator- $40
Intake manifold -$30
Block mounted Oil Cooler- Doesn't look to be leaking $55
Flywheel & Clutch- 1 piece flywheel, clutch needs relined $150
Block adapter- $35
Ford factory steel wheels 16x7 fits all 8lug Chevy/Dodge trucks, still sporting some 235/85R16 Michelin's with some tread left. $45/pair, or $70/all 4
All the prices are up for negotiation, so make offers
I will ship anything, but you're paying the actual shipping. I DO NOT WANT this stuff sitting in my garage forever, so start throwing me offers! If there is something you want, but don't see listed, let me know. Block is trash, probably wouldn't want the crank/cam/pistons out of this motor
Do you mean the brackets the are attached to the frame, or the motor mounts bolted to the block?
If you mean the motor mounts on the block, I've got them. Take $30 + shipping...
I would like to purchase your transmission if itis still available. I have a 89 F250 7.3l 2 WD deisel ready to recieve the transmission. here is my contact email address wemeny@gmail.com
