Sponsored by: Real Truck
Axle Code
Old Sep 16, 2010 | 05:53 PM
NJBronco94's Avatar
NJBronco94
Axle Code
Hi guys.....looking for some help. I just purchased a 2003 F250 with the 5.4. I'm trying to figure out the axle code...it's CT. Does this make sense?
I've seen all the various codes for the F250 and this is not one of them?
Thanks!
Old Sep 16, 2010 | 05:55 PM
scraprat's Avatar
scraprat
Top Answer: 5
Where are you looking at the code on the truck? Rear axle?
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old Sep 16, 2010 | 05:57 PM
redford's Avatar
redford
FTE Leadership Emeritus
What is the axle code on the door frame sticker?
Old Sep 16, 2010 | 06:13 PM
NJBronco94's Avatar
NJBronco94
Thanks for the quick replies guys!
Had my 9 year old daughter look at the sticker......it's C1, 3.73 (I'm in denial about getting glasses).
I just picked up the truck today from the dealer. It's my first F250 and I love it. The truck looks brand new.
Old Sep 16, 2010 | 06:16 PM
redford's Avatar
redford
3.73 is the most common ratio for the 5.4L.
Old Sep 20, 2010 | 12:09 PM
Robert Lantz's Avatar
Robert Lantz
Hi could you please help me I am having a very tough time trying to find brake rotors for my 2000 F450. I know it starts with identifying my axel but that is the great mystery. The info off the tag doesn't seem to match whatever data base I come across and I'm kinda hanging. The rotor is huge 15"-16" and all books computers say it should be 13" or 14.5". Heres the kicker: I only have 8 lug axels and the rotors that are suggested say they should be 10 lug. My axel tag reads as follows: YC35 JA 606225-1 also there is some numbers 47844 AD W2 on the rearend cover. Please help I need to get my daily driver back on the road!
bigdoggs1
2004 - 2008 F150
May 15, 2017 01:07 AM
fishbones182
Sep 19, 2016 06:16 AM
ComputerCowboy
Jan 5, 2012 12:20 AM
boggerted
Apr 7, 2009 12:15 PM
xxxman
Oct 26, 2003 09:40 PM
