If you hear a clicking under the dash above the gas pedal/ brake pedal when you push the horn then it's probably the horn itself. That clicking is the relay which is wired to the horn pad through the steering column. Mine went out on the turn signal switch at the connection to the steering wheel, but yours sound like the horn itself.
Something to look at is the horn connection. If it fell off you will not get noise.
(I need to hook mine up when the weather warms up...mine fell of and is laying next to the horns)
Bruce Big Red Bronco
