Steering question
Old Sep 16, 2010 | 02:37 AM
Big_Dom's Avatar
Big_Dom
Question Steering question
Okay, so a few days ago, after I had done some off-roading, my steering wheel started making a werid almost whizzing noise and vibrating everytime I turned it a little bit. So I put some power steering fluid in it (it was like bone dry), and it stopped. However, I recently got 3ft of air from a railroad crossing, and went to work and I came out roughly 7 hours later and it was doing it again. Did I **** sumpin up? I haven't checked the fluid again yet but I did notice a bit when i pulled out. Could I have caused a leak in my powersteering?
Old Sep 16, 2010 | 10:53 AM
tbear853's Avatar
tbear853
Question
Probably.
Is it also "low" again?
Surely you've checked by now ...
... you could have checked the level faster than logging on here to ask.
Just sayin'
Old Sep 16, 2010 | 11:43 AM
704 dentside man's Avatar
704 dentside man
Yes...you probably screwed something up. But there should be a nice little puddle somewhere.
Old Sep 16, 2010 | 12:55 PM
83sd's Avatar
83sd
I'll bet you did. Why not just check your fluid level instead of logging on here and askingo us if you messed something up? Crawl under it and look for damage. Why would you abuse a truck you wanna drive everyday by jumping it?
Old Sep 16, 2010 | 01:24 PM
Big_Dom's Avatar
Big_Dom
i didn't do it on purpose, long story short, there are a lack of signs and many well hidden railroads in Montana.
Old Sep 16, 2010 | 01:37 PM
Joseph69's Avatar
Joseph69
Abuse it and have fun with it, its yours, you can.
When the power steering pump starts to go out it will start whining like that. If it is not low, it could be that, look into the AC Delco upgrade from the 80's van steering, direct bolt in and works much better.
If the fluid is starting the leak out, it could be the lower shaft seal on the steering box. It is sealed with o-rings and you'll either have to rebuild it or have a rebuilt one put in.
Old Sep 16, 2010 | 02:05 PM
jsutton's Avatar
jsutton
I have nothing to add to the issue the OP has but I'm interested in the AC Delco 80's van upgrade, because I need a new PSP. Mine leaks because I'm a dumb a$$ and put a breaker bar under the reservoir to leverage it up to put tension on the belt. That caused the reservoir to bend and pull away from the mating surface some and now it leaks a little bit.
Old Sep 16, 2010 | 02:21 PM
Joseph69's Avatar
Joseph69
Cardone 20-7878F - Power Steering Pump | O'Reilly Auto Parts
They call it the Saginaw Steering upgrade, but the pump was originally an AC Delco pump now made by Saginaw IIRC. Have one on my truck, the hose has to change, I used a van hose on my 2wd. Bring the original hose from your truck, and make sure to match the o-ring fitting on the pump and the double flange fitting on the original steering box.
Old Sep 16, 2010 | 04:57 PM
Big_Dom's Avatar
Big_Dom
Talking
haha thanks joesph, you are very helpful, and to be honest, i felt more badass than Ken Block lol, he rallys in a Ford Fesita, i do it in a 76half ton pick-up hahahahaha.
