f100 302 PROBLEMS please help
Old Sep 15, 2010 | 09:31 PM
canadianf100007's Avatar
canadianf100007
i recently acquired a 1978 f100 302. When bought it ran, but not well. i replaced the spark plugs and wires, messed up once on the firing order but have fixed it. the problem is now the truck wont start at all it keep turning over and over. I recently replaced the coil, and am thinking of buying a reman. 2100 carb from a local parts store. any suguestions?
Old Sep 15, 2010 | 09:45 PM
25aniv's Avatar
25aniv
Have you confirmed you are getting fuel and spark? Go through the basics before buying parts as there are quite a few possibilites for failure here.
Old Sep 15, 2010 | 10:45 PM
Flat_Ford's Avatar
Flat_Ford
try...checking for spark...if you are getting spark...recheck the firing order...if that doesn't do it...make sure the coil and all is hooked up right...if all the firing checks out okay...pour a little gas in the carb...if it hits or trys to run then look in the carb barrel and pump the gas...see if it squirts...if not check your filter or replace it...it's cheap and can never hurt to change the filter...and the number one thing i always check first....MAKE SURE YOU HAVE GAS IN THE TANK...i learned the stupid way.
