gasket set
Old Sep 15, 2010 | 04:26 PM
2005f-150's Avatar
2005f-150
gasket set
is their a place to get a full gasket set for my 1988 7.3l? my head gasket is leaking and i am not shure about the oil cooler leaking yet. i am thinking about just pulling the motor and rebuilding it just to be shure it is fixed and in good condition.or i might just replace the head gasket and go from there because their is a tight time and budget.
Old Sep 15, 2010 | 06:09 PM
farmert's Avatar
farmert
Any good parts house can get the full gasket set. It won' have the oil cooler o-rings though.
Old Sep 15, 2010 | 06:45 PM
1994F2507.3L's Avatar
1994F2507.3L
List: Engine Kit Gasket Set - 1994 Ford F-250 | O'Reilly Auto Parts
Old Sep 15, 2010 | 07:29 PM
2005f-150's Avatar
2005f-150
i know it is a pita but if i let tne motor in the truck how hard is it to replace the head gasket? and is their any other gaskets i will need or anything else? also about how long will it take?
Old Sep 15, 2010 | 07:49 PM
whenry912's Avatar
whenry912
I just did mine in the truck, didn't rush, so I cant say how long start to finish, probably close to 20 hours. Getting the heads in and out was the only real issue, but I used an engine hoist so it wasn't too bad...
make sure you get a return line kit for the injectors in addition to the gaskets.
Old Sep 15, 2010 | 08:23 PM
fonefiddy's Avatar
fonefiddy
I've done 6 set's of HG's in truck. Is a PITA with a turbo. NA is easy.
Definately spend the $40 for the Oil cooler rebuild. Is a TOTAL PITA otherwise.
