Spark plug wire suggestion
on
Keep in mind, by default, (resistance=heat) higher resistance wires will fail sooner, w/ all other variables being the same. Insulation quality is just as important, as it's effectivness (or lack of) will render the core structure irrelevant. High output coil's are a equal opportunity discharge proponant, preferring the path of least resistance. If that path is other than your spark plug, you lose!
I did check the resistance on each wire. Most of them were in the 7500 ohms range. The number 7 wire was 10,500 ohms. Does this sound reasonable for these wires?
The resistance is going to depend on what type of wires they are. Some use a built in resistance to suppress EMI, others use a wire wound around the center core for that purpose. Your issue is going to be high voltage leakage due to the insulator breaking down over time. A simple DC resistance check will never "measure" that value.
on
Misting water on & around the plug wires with the engine running in the dark will give visual reference to leakage. Both at idle, & w/ rpm varied will show a good indication of what's really going on.
The less path resistance, the more likely is will stray from it's insulative confines. The better the insulative confines, the more resistance will have to be overcome to stray.
On my 95 4.9 the original wires are functioning but the boots and terminals are becoming worn and I plan to replace them later this month with a set of "name brand" spiral core wires. It did pass the mist test and some nasty rain from "EARL" but in this case change is good. The cap, rotor, and maybe the coil will also be replaced at the same time.
regards
rikard
regards
rikard
Rik I'm a firm believer in the old addage *if it aint broke don't fix it*. BUT you sound like your going to be doing the same thing I'm doing with my 1990 4.9L and in this case I'm going to the Accel high voltage electronic super coil and I am going to replace: Cap/Rotor/Plugs/Wires and take the added measure of also replacing the ignition module too, so that the ignition system will be comprised of all new components Except for the distributor assuming it's still good, if it's bad it'll get replaced aswell
on
regards
rikard
regards
rikard
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
#28
on
Rik I'm a firm believer in the old addage *if it aint broke don't fix it*. BUT you sound like your going to be doing the same thing I'm doing with my 1990 4.9L and in this case I'm going to the Accel high voltage electronic super coil and I am going to replace: Cap/Rotor/Plugs/Wires and take the added measure of also replacing the ignition module too, so that the ignition system will be comprised of all new components Except for the distributor assuming it's still if it's bad it'll get replaced aswell
The TFI (ICM) & PIP are definitely if it ain't broke items, but the other items will degenerate at a much faster rate. Coils weaken w/ age/use. One reason plug gaps are ranged rather than one single measure (.042-.046/ .044 being the average) This is the reason you can increase your gap by 25% after the ignition system upgrade.
#29
