Need CEL code help 2000 3.0l 2wd
Old Sep 14, 2010 | 12:02 PM
nightshifter's Avatar
nightshifter
Anyhow, my ranger has been sitting quite a bit this summer due to a lack of a/c. I took it to pick up the wife at work last night and it barfed up the following codes: P0136, P0120, and P0028. I've spent an hour, searching, poking, prodding and googling and I can only find one of these codes listed (an O2 sensor code, typical). Can someone help me out? I'd really appreciate it.
Old Sep 14, 2010 | 12:33 PM
martin_csr's Avatar
martin_csr
Not sure how much help this will be... Trouble codes
P0120 = Throttle/Pedal Position Sensor/Switch A Circuit
P0128 = Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0136 = O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
I have a 2000 Ford Powertrain-Control/Emissions Diagnosis manual for sale ($5 + shipping).
The chart in it says that the possible causes of the P0136 are: pinched, shorted, or corroded wires; crossed sensor wires; exhaust leaks; contaminated or damaged sensor. The other two codes aren't listed in the DTC section.
Old Sep 14, 2010 | 02:33 PM
nightshifter
That one code was a P0028 not a 128. Any info on that?
Old Sep 14, 2010 | 02:57 PM
martin_csr's Avatar
martin_csr
Nope, it's not on the list in the manual that I have. There aren't any codes below P0101 (ie, there are no P00XX codes in the dtc section).
OBD-II (Check Engine Light) Trouble Codes
P0028 Intake valve Control Solenoid Circuit Range/Performance Bank 2
Old Sep 14, 2010 | 03:55 PM
wtroger's Avatar
wtroger
If it has been sitting a lot and it out of blue spit those codes out I would look for mice/rat/squirrel wiring damage.
Old Sep 14, 2010 | 07:30 PM
powersmoked's Avatar
powersmoked
CodeKey: Unlock the Mystery of your Check Engine Light
Old Sep 15, 2010 | 12:46 AM
nightshifter
okay, that's an awesome site, bookmarked & thank you!
Wolf1200
1997 - 2003 F150
May 6, 2009 01:28 AM
radunegruion
3.8 & 4.2L V6
Feb 12, 2007 08:09 AM
aefool13
Aftermarket Products
Aug 24, 2006 05:59 AM
ritchie46
1997 - 2003 F150
Mar 9, 2004 08:53 PM
