300 efi ignition ?
Old Sep 14, 2010 | 06:49 AM
haukin99sdp's Avatar
haukin99sdp
300 efi ignition ?
i would like to upgrade the ignition on my 89 300 i6 efi. i have seen some talk on here about the duraspark and was wondering if that would work on an efi? if not, what dizzy would you guys recomend? i am also looking at adding an msd box and coil?
any and all suggestions plz and thx!!
Old Sep 14, 2010 | 10:23 PM
Harte3's Avatar
Harte3
The Duraspark won't work with an EFI engine. Your engine has TFI. The TFI is the Ford version of GM's HEI and is more than sufficient for the job. Some even use the 4-pin GM module with a TFI coil as an upgrade to the DS2 system on carbed applications.
Old Sep 16, 2010 | 10:13 PM
66 bronco roadster's Avatar
66 bronco roadster
first year 300 EFI???
At some point I would like to do a 300 EFI motor swap in an early Bronco. What was the first year and models had a 300 EFI motor? My brother had a 87 F-150 but I can remember if it had carb or fuel injected.
Thanks Jeff
Old Sep 16, 2010 | 10:53 PM
court1100f's Avatar
court1100f
1987 was the first year the 300cid/4.9L/4900cc engines came Factory with EFI the Following year 1988 the 351W and 460Cid blg block were equiped with EFI Speed Density to be specific in 1996 they switched to OBD2 and Mass Air Flow EFI
Old Oct 5, 2010 | 12:56 AM
haukin99sdp
bump.........
Old Oct 5, 2010 | 01:16 AM
court1100f's Avatar
court1100f
Hey man whats up??? I'm fixin to be looking into what options are available myself For one thing look up an ACCEL Electronic Super Coil model 140008 get that and the associated low ohm resistance wires and it'll wake up the ignition system considerably
EvinrudeDude300
23
Mar 3, 2025 12:28 AM
Phil Fleming
Jan 23, 2017 10:32 AM
rentakid94
Nov 28, 2012 11:31 AM
ndmccann
Oct 16, 2011 10:50 AM
rikfish
1978 - 1996 Big Bronco
Jun 11, 2002 07:41 AM
