Oil & Lubrication
4.6 using 5w-30 analysis
Old Feb 19, 2003 | 06:48 PM
Flash's Avatar
Flash
Got this info from another site. Thought it might be interesting to post. A 99 F-150, 4x4, auto with 80000 miles on the truck. Truck is driven 50% on freeway and during this oil change has been subjected to below zero temps. Oil is Valvoline Durablend 5w-30 and valvoline oil filter and air filter is used. Mileage on oil is 4038 miles. Analysis as follows:
Copper 2
Iron 16
Chromium 1
Lead 0
Aluminum 3
Silicone 4
Moly 3
Sodium 2
Magnesium 12
Zinc 908
Phos. 721
Calcium 1980
TBN 8.0
VIS @ 100C 10.5
The only elevated part is the iron which would be expected because of the cold startup in subzero weather. Note low level of silicone- now that's a good air filter. Considering that the 4.6 has not had any of the internals changed to actually warrant a 5w-20 oil, it looks like a good grade of 5w-30 would do nicely for folks that live in heat prone areas. Comments?
Old Feb 19, 2003 | 07:18 PM
BigMattXXL's Avatar
BigMattXXL
Numbers look good. Did the lab give you a recommendation for your next change interval?
XXL
Old Feb 19, 2003 | 08:00 PM
mikemc's Avatar
mikemc
This is the route I am taking with my '02 Ranger. 5W30 has been recommended for these motors for years with good results so that is what I am using in the Chevron Supreme. I will send in a sample at around 20K once the engine is completely broke in.
Old Feb 22, 2003 | 11:55 AM
Starratt04's Avatar
Starratt04
i run 5w30 in my cobra. it works well
bismic
Jun 19, 2009 12:23 PM
TallPaul
Oil & Lubrication
Jul 8, 2005 12:11 AM
TallPaul
Oil & Lubrication
Jun 2, 2004 11:01 PM
TallPaul
Oil & Lubrication
Apr 1, 2004 09:17 AM
seldont
Oil & Lubrication
Feb 22, 2004 10:08 PM
