top 10 ways to kill an engine
Old Feb 19, 2003 | 04:58 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
just wondering if anybody's got any cool ideas to kill an engine. i'm workin on a top 10 list. my "best" idea so far is to hook up a tube with a bunch of bbs suspended over the carb with a trap door hooked up with a long string and then start the engine , drop a brick on accelerator , run away , then pull the string to release the bbs and see what happens. any other ideas?
Old Feb 19, 2003 | 05:10 PM
Sycostang67's Avatar
Sycostang67
Drain the radiator and hit the freeway, it worked for me. Or do like my buddy, and put 39" tires on a bronco with a stock 302 and stock gears and remove the air cleaner. Of course that was a slow painful death. He wanted a reason to install a 351.
Old Feb 19, 2003 | 06:14 PM
V10KLZZ71S's Avatar
V10KLZZ71S
fill the crankcase with 3 gals of gasoline, remove a spark plug, knock a hole in the piston, use a VERY long remote starter device,
do the brick accelerater thing then start it!
Old Feb 19, 2003 | 06:35 PM
Joe fix it's Avatar
Joe fix it
Pump it full of sugar
put brick on gas pedal, let rev till it'll rev no more
sand in cylinders, crank over alot
I am pretty good at the breaking of that engine, just don't ask me how to fix it afterwards
Old Feb 19, 2003 | 07:36 PM
airharley's Avatar
airharley
Personally I like the 450 shot of NOS without extra fuel to go with it. Makes for nice crystalized valves and melted pistons.
Oh and don't forget scouring powder in the crank case oil. bores everything over for you, shaves the conrods, eats the oil pump, kills the lifters and cam, and so on....
Old Feb 19, 2003 | 08:23 PM
429 4v's Avatar
429 4v
how about a brick to the petal till it wont rev anymore,then shoot a hole in the block with a .50 cal
Old Feb 19, 2003 | 08:39 PM
airharley's Avatar
airharley
the only problem is how many have access to a .50 cal M2, GAL 16, or XM-218? I know I do but I can't bring it home to shoot the engine. If you want to get midevil on it then use an incinerary grenade to melt through the top of the intake and through the block? It'll keep burning through the concrete or pavement too!
Old Feb 19, 2003 | 10:41 PM
samhihn's Avatar
samhihn
Give the vehicle to my daughter to drive for an extended period of time! Engine replacement, trans rebuild and body shop work will be inevitable jeesh!
Old Feb 20, 2003 | 10:30 AM
justo2000_2000's Avatar
justo2000_2000
Have you guys ever heard of a thermite reaction? Basically it is very small aluminum filings mixed with iron(III) oxide (rust) and ignited with something like a fourth of july sparkler, it gets hot enough to convert the rust into liquid iron in a couple of seconds. My idea: Take off air cleaner, put a styrofoam or paper coffee cup full of this stuff on top of carb, light sparkler (use a long one so you have some time) start it, brick on the gas pedal, see how cool your cylinders look when they're full of molten iron afterward
Old Feb 24, 2003 | 07:01 PM
Quantrex's Avatar
Quantrex
Lock the throttle wide open, start it up and at max rpm pour a gallon jug of water down the carb. It'll hydraulic lock the pistons and blow the crank out of the oil pan.
Old Feb 25, 2003 | 09:20 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Wow, I never knew ther were so many people out there just like me. Just remember to take the hood off an these experiments unless you want a new one.
steven
Old Feb 26, 2003 | 12:39 PM
dutchtreat's Avatar
dutchtreat
Watch out for guns!!!!
A friend has a "for real" Shelby mustang.
One night while out doing a little stop light to stop light action. He out ran the other guy pretty bad......the looser pulled up next to him and shot the engine with a 357 mag. That slug went through the front fender and into the block....I was in the passenger seat.
Old Feb 26, 2003 | 09:04 PM
Quantrex's Avatar
Quantrex
Hope you got the loser's tag number. Thanks to some anti-gang laws here; anyone firing a weapon from a vehicle "in the general direction of another individual", (aka. "drive by"), can be tried for attempted murder.
