Hey whats going on people I asked this back in 08' on the 67'-72' section with no luck so it's been a couple of years so I'll try again has anybody put a E4OD into a 67'-79' truck after market controllers are out there just hoping it is going to fit with out or minor body mods.I realize there is going to be cross member drive shaft work got the trans for the best price in town FREE my brother parted out a 89' F350 a OD trans behind the 460 would be great let me know thanks [Texans beat the Colts ? Im confused]
I did it a few years ago, set up is still working although I did have to replace the transmission since then.
It's big, real big but it does fit. Aftermarket controller works fine once you dial it in. Be prepared to spend a lot of time test driving with your laptop plugged in.
You can also check the transmission forum as well for more info.
Would I do it again? No, I'd find a ZF 5 speed and go manual. ZF for small blocks/I6 are hard to find. Nothing wrong with the swap I just miss driving stick.
hughes builds a manual valve body and no electronics. I'm in the process of doing this build for my 1970 ford crewcab 4wd with 400 ford. I run a manual valve body in my c-6 and will work. www.hughesperformance.com. Something to consider. Drop a message if curious. kinda like this idea. The ZF is a good idea but had problem with overdrive gear before and I'm partial to auto's for 4wd.
