d. window as well as gem issue
Old Sep 12, 2010 | 12:50 PM
Biggg72's Avatar
Biggg72
Question d. window as well as gem issue
the issue with my driver window is no up and down. the other windows work fine individually and from the master control. i thought i may have a bad switch because when i hit the switch to go i hear a click like its the relay (replaced the relay - no change). i then direct power to the plug, the up popped as the window was already up and i was just checking, but going down, same issue, it sounds like the relay ( change to another relay just for s&g's - no change).
so i look in the helm electrical and it directs me to possibly the gem - generic electronic module connector. it is on the underside of the junction box/ fuse box. im thinking the plug goes into the fuse panel is this correct? if so is it possible for the plug to be bad or could the fuse panel have an issue if the gem plugs into it?
it has gotten to hot to be crawling around under the dash, but how do you take the fuse panel out, i dont have a helm maintenance yet they have been sold out forever?
tia
Old Sep 12, 2010 | 04:33 PM
Biggg72's Avatar
Biggg72
anyone? the heat is letting up.
Old Sep 12, 2010 | 06:19 PM
alloro's Avatar
alloro
Take the plug off the window motor and connect it to a meter. If you don't get power when pushing the switch, then change the switch.
Old Sep 12, 2010 | 09:46 PM
Biggg72's Avatar
Biggg72
thanks. i ended up finding another problem that i missed and forgot about and didnt get back to it, but i will check this tomorrow.
Old Sep 13, 2010 | 11:55 AM
Biggg72's Avatar
Biggg72
Ok I did that and tried a new switch. When I went to let it down tje window just went down about a 2" and quit. It will not go up or down anymore. I'm going to have to direct power the plug to get it back up. I'm thinking its the motor now. When replacing the motor will taping the window up be ok or do you have to support it another way?
W ihen hit down on the switch, the motor sounded like it was on its last leg anyway.
Old Sep 14, 2010 | 07:09 AM
c_hohensee's Avatar
c_hohensee
Taping the window up will work fine (if you use enough tape).
Old Mar 7, 2011 | 07:22 AM
fallguy's Avatar
fallguy
Did replacing the motor work for you? I have the exact same issue and I replaced the motor and it worked when I put everything together in the garage....then this morning when I am driving to work I test it out and now it's doing the exact same as you described. This is getting annoying.
Old Mar 7, 2011 | 10:04 AM
Biggg72's Avatar
Biggg72
Yes I replaced the motor and everything is good. All I need to do now is grease up the window channel a bit after I clean them.
boots6868
Jan 15, 2019 05:39 PM
sevensecondsuv
Jan 2, 2017 03:23 PM
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
Traildust
May 18, 2014 03:48 PM
siredward20
16
Oct 6, 2013 09:43 AM
