Modular V10 (6.8l)
Fuse box issue
Old Sep 12, 2010 | 08:55 AM
ivplay's Avatar
ivplay
Fuse box issue
It all started with my wipers not working at times then not at all. Bought a new wiper motor, still not working. Bought a new turn signal wiper switch, still not working. By chance one morning I banged on the fuse box cover and the wipers started working so I thought the fuse was loose. It was loose so I just touched the fuse and the wipers and the wipers quit then held pressure on the fuse and they worked. I got a tooth pick and wedged it in besides the fuse. Work fine now but would like to know how to properly fix it instead of jerry rigging it. Don't really want to buy a new fuse box because if all the electrical connections and headaches that come with replacing the box.
Old Sep 13, 2010 | 09:17 AM
bakon's Avatar
bakon
bend the tabs which hold the fuse. Hard to think you didn't check the fuse first.?.
Old Sep 13, 2010 | 11:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The contacts in the fuse box can be changed, but like bakon said, bend the tabs.
Old Sep 14, 2010 | 11:15 AM
tmehrkam's Avatar
tmehrkam
Mine had an issue with the fuse box.
When I purchased it I noticed that there were a number of copper connectors that were forced into the socket between the fuse contacts.
This allowes you to connect a spade lug connector to tap the power. I found evidence that my truck had a two way radio installed. Coax and holes for a microphone.
I removed the connectors and had problems with the fuses involved. They would not make contact. I reinstalled the connectors and have not had any problems since.
Maybe yours had a similar device installed before you purchased it. You could fix it by reinstalling some connectors. Where to get them?
Old Sep 17, 2010 | 07:48 AM
ivplay's Avatar
ivplay
Thanks guys, I used an ice pick and bent the connectors in the fuse box and it works great. Thanks again.
IVPLAY
JPD Motorsports
Jan 7, 2015 07:06 PM
jawmarq
Jan 5, 2014 04:40 PM
tbe2002
Dec 17, 2012 09:09 AM
