pulling my forklift
Old Sep 12, 2010 | 08:06 AM
John 300's Avatar
John 300
pulling my forklift
When im pulling my forklift i get a vibration mainly when taking off on a in
cline. It only does it when im taking off .My truck is 2004 f250 automatic this problem is starting to worry me has anybody had this problem
Old Sep 12, 2010 | 11:22 PM
Benchwrench's Avatar
Benchwrench
check your exhaust pipes for clearance issues, it might be rubbing somewhere like the downpipe for example, if nothing there you may also consider checking the 5 bolts that hold the turbo down. You need to just poke around a bit or give more detail describing your vibration.
Old Sep 13, 2010 | 04:10 AM
scsmith42's Avatar
scsmith42
I've experienced the same situation with both my '03 and '05 F350's (6.0 with a torqueshift tranny). The vibration only occurs under a high load, and then only for a few seconds.
My '08 F450 also does it occasionally, but less often. However, the '08 has 4:88's, and the F350's had 4.11's, so there is less loading on the '08 tranny.
Based upon my experience, I would not worry about it, but would be somewhat gentle in 1st gear).
Old Sep 13, 2010 | 11:01 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Just wondering how much weight are you pulling?
Old Sep 13, 2010 | 01:21 PM
John 300's Avatar
John 300
the forklift wieghs about 18,000 the vibration fills like its in the back.The truck has 180,000 miles on it no problems yet well its had head work done on it but its been a great truck other than that.
Old Sep 13, 2010 | 01:25 PM
02GrayPowerStroke
Sounds like you are pulling too much LOL
Old Sep 13, 2010 | 01:58 PM
brickie's Avatar
brickie
Wow!You don't baby that thing.That is an insane amount of weight for a single axle truck.
Old Sep 13, 2010 | 02:04 PM
John 300's Avatar
John 300
I dont pull that kind of wieght every day 1 or 2 times a month and its about 60 miles max.
Old Sep 13, 2010 | 02:42 PM
Sarge261's Avatar
Sarge261
You may want to try greasing the slip yoke. I had almost the same issue with my 06, and greasing the slip joint on the rear shaft fixed it. There is a write up in the tech folder on it.
Sarge
Old Sep 13, 2010 | 06:43 PM
cheezit's Avatar
cheezit
sounds to me like you overloaded a little bit. I think you are having a pinion angle issue causing it. been there donr that.
can you move the forklift back on the trailer a little bit and take some weight off the toung. That may help.
Old Sep 13, 2010 | 09:22 PM
smokersteve's Avatar
smokersteve
I have a vibration from initial take off. I took it to the dealer and they said it was my carier barring. The height of it needed to be adjusted so the vibration will go away.
Old Sep 13, 2010 | 09:24 PM
cheezit's Avatar
cheezit
thats what I said. droping the center bearing down will drop the driveshaft down and change the angle.
simply repositing your load may do you just as much good.
Old Sep 13, 2010 | 10:23 PM
smokersteve
Cheezit, am I wrong for calling it a carier bearing???
Old Sep 13, 2010 | 10:34 PM
cheezit's Avatar
cheezit
nope just me fatfingering the keyboard again.... sorry.
you can undo the carrier bearing and place a few washer in it and see what happens.
it may or may not get you there.
Old Sep 14, 2010 | 07:24 AM
Sarge261's Avatar
Sarge261
Cheez,
Wasnt there a bulletin on this issue for some of the SD trucks and they had a kit with shims or something. I thought it was LWB trucks with the 2 piece drive shaft?
Sarge
